Radiator fans not coming on 94 z34
Oh that's a drag. Sorry to hear that.
It’s all good I’ve already ordered the gaskets, head bolts, tune up kit and some other parts from rockauto. I guess the positive side is that now I can clean the engine bay up and get everything sorted, definitely a drag because it’ll put a hold on cosmetics but oh well I would rather it run tip top than hurt the internals like it probably would if it kept getting driven.
I had an issue with my primary fan not coming on as well. (91 LQ1). It was the temp sensor in my case; from memory the sending unit was on the rad but I could be wrong, its been a few years.  Found out very shortly after the primary fan motor was fried and was causing a huge amp draw when it was on.  I changed both and problem solved.
