bluegtp91 Posted January 11, 2018 Report Posted January 11, 2018 Per: TheOtherNick dog bone=15mm fender brace=13mm supercharger=10mm, one 13mm tb=10mm, 2 8mm on the support bracket for n/a cars egr=13mm egr tube bolts=3/2" valve cover=3/8 alt bolts and nut= 15mm map bolts=10mm water pump pulley=8mm front cover and water pump 10mm and 13mm crank bolt=15/16 rear cover=3/8 oil pan 3/8 head bolt= 5/8IIRC head stud nut= 1/2" 12 or 6 point x over nuts= 13mm starter bolt=15mm starter batter pos nut=13mm 14mm on some after market starter relay wire=10mm p/s pump=13mm tensioner pulley=15mm or t55 torx icm bracket=15mm cam bolt= 1 1/16" or 24mm IIRC torque converter bolts=18mm transmission bell-housing bolts=18mm rear engine to trans bracket bolts=13mm axle nut 32-36mm depending on year and axle manufacturer strut to knuckle bolts=21mm ball joint nut=18mm 19mm on some aftermarket strut top nuts 15mm front sway bar bushing clamp bolts=15mm links 13mm-15mm depending on manufacturer rear sway bar link nuts=18mm, 15mm on back to hold the ball manifold bolts 13mm 02 sensor= 7/8" icm harness bolt=7mm Lim bolts=3/8" front hub bolts=1/2" rear hub bolts=10mm blower motor/blower resistor 7/32" small dash bolts=7mm larger ones 13-18mm Seat bolts=T60 torx IIRC headlight mounting bracket bolts=10mm(2) A/C compressor front nuts 100 N.m (74 lb ft) A/C compressor rear bolts 31 N.m (23 lb ft) Camshaft Sprocket Bolt First Pass 74 lb. ft. Final Pass + 90* Connecting Rod Cap Bolt 20 ft.lb +50* crankshaft balancer bolt 150 Nm (111 ft. lbs.) + 76* Crankshaft Main Bearing Cap Bolt 30 ft. lbs. \ +110* Crankshaft Main Bearing Cap Bolt (Side) 11 ft. lbs. +45* Comp Cams rocker bolts 23 lb ft. EGR Valve37 lb. ft. (EGR) inlet/outlet pipe bolt (21 ft. lbs.) Exhaust Manifold Bolt/Nut 22 lb. ft. exhaust manifold pipe stud nuts 32 Nm (24 ft. lbs.) exhaust crossover pipe bolts and studs 18 Nm (13 ft. lbs.) Flywheel Bolts11 lb. ft. +50* front head First pass 37 lb. ft. Second pass +120* Final pass +30*(only 96-01 cars inner 4 bolts) When using head studs work your way up to 90ftlbs using the same picture, I did three passes on mine. 30-60-90knock sensor 19 N.m (14 lb ft) LIM 11 lb. ft. Start in the center and work your way out. oil pan bolts 14 Nm (125 inch lbs.) Oil Pump Pipe and Screen Bolt 11 ft.lb oil level sensor 20 Nm (15 ft. lbs.) Power steering pump bolts 25 ft. lbs Tighten the valve rocker arm bolt \ 15 Nm (11 ft. lbs.) +90* supercharger 17 lb. ft. Start in the center and work your way out. supercharger snout 15 lb.ft. Start in the center and work your way out. Throttle Body Bolt/Nut 89 lb. in. (7.5 lb. ft.) Upper plenum 89in.lb. (7.5 lb. ft.) Water Pump Bolt (Long) 25 ft.lb Water Pump Bolt (Short) 16 ft.lb Water Pump Bolt (SAL) 89 in.lb (7.5 lb. ft.) Water Pump Pulley Bolt (3.8L) 115 in.lb (9.5 lb. ft.) Quote
