98gpgt Posted January 11, 2018 Report Posted January 11, 2018 Who makes cars like this! The damned thing should just come out. I haven't yanked on it much, with my luck I'll damage the harness. I did cut the plastic retaining thing, could use a tie wrap when I'm done (but why? That harness is so taaught). I wasn't actually on my back, rather was working with a mirror on the floor. Should I just yank away or is there yet another retainer I can undo to create some slack in tne harness. Quote
Imp558 Posted January 11, 2018 Report Posted January 11, 2018 It has to be routed wrong or something. If you have a little pick plugs are easier to unplug. The secondary lock isn't necessary. Quote
digitaloutsider Posted January 11, 2018 Report Posted January 11, 2018 It should just "come out". There are only 3 bolts that hold the blower motor in, IIRC. One is shoved up way against the carpet toward the firewall. Quote
98gpgt Posted January 11, 2018 Author Report Posted January 11, 2018 I got the 3 bolts out. A guy on youtube also said it was a pita. I'll look into unplugging the harness. And...there's drops coming down as I worked the thing. Another guy on youtube said the plastic band? underneath the wipers needs to be siliconed. There's also a bit of rust on the blower itself. Maybe I didn't need to buy a replacement, just clean up the old one? Quote
digitaloutsider Posted January 11, 2018 Report Posted January 11, 2018 There's a plastic shield you can find on newer Regals and Grand Prixs that covers up the giant HVAC intake hole under wiper cowl. Check later (maybe 2000+) GPs and Regals for it. Quote
