Moozery Posted December 28, 2017 Report Posted December 28, 2017 I'm wanting to do the Dual Piston Impala Calipers + SS Extended Lines upgrade soon, and I notice Will at Overkill always heavily recommends using police spec pads, which appear to usually be semi-metallic. Although besides him, I've never heard of someone recommending semi-metallic/police pads. Even for myself I've always stuck with regular ceramic pads. I was wondering if anyone had any feedback on these kind of pads and if they'd really recommend them or not. I've done some reading on them and it sounds like the main concerns with these are noise and brake dust. Though as long as the noise isn't that brake squealing type I really couldn't care less, and as for the brake dust I just painted my summer rims black (gloss though) and I'm not sure if that will make the dust really noticeable or not. What's your guy's thoughts? Quote
55trucker Posted December 28, 2017 Report Posted December 28, 2017 In '04 semi metallic pads were still the OEM norm for brake use. They have better cold stop abilities than ceramic, they have a wider operating range, semi absorbs heat better than ceramic does, they are better where brake fade is concerned. The downside is that metallic pads will wear the rotor quicker, produce more dust, also can allow squeaking (the metallic imbedded) when a light pressure is applied. Ceramic is easier on the rotors, produces less dust, the pads last longer, but they are not designed for continued aggressive use. .....in an emergency cold hard stop.......there's no question as to which pad will respond better *a shame that Will moved to Vancouver* Quote
Moozery Posted December 28, 2017 Author Report Posted December 28, 2017 *a shame that Will moved to Vancouver* I know what you mean. A shame it's so hard to get hold of him these days too I think good ceramic pad will probably work just fine for me, I'm not an aggressive stopper at all. Those plus the calipers and lines should be a big upgrade to begin with anyways. Quote
55trucker Posted December 28, 2017 Report Posted December 28, 2017 It was a bit of a luxury having him close by for those of use who were members of the now defunct OQCGP. Not necessarily myself but those who were heavily into 2nd & 3rd Gen *blown* engined cars came to rely on him quite a bit. Quote
scottydoggs Posted December 28, 2017 Report Posted December 28, 2017 i suggest you search R1 concepts on ebay and get the drilled and slotted E line rotors with scorched ceramic pads, i promise you will love them, and buy nothing else afterwards. i got a set on the regal with f bodys up front, just installed them on my tahoe. stops like a champ. Quote
bluegtp91 Posted December 28, 2017 Report Posted December 28, 2017 R1 Concepts has been top notch for years and they have great prices. Will also vouch with the zinc coated rotors they never rust at all. Imp558 1 Quote
Imp558 Posted December 29, 2017 Report Posted December 29, 2017 R1 Concepts has been top notch for years and they have great prices. Will also vouch with the zinc coated rotors they never rust at all. Zinc is actually really easy to plate at home with. I got geared up to do it but haven't had time to experiment with it. https://video.search.yahoo.com/video/play;_ylt=AwrDQ2p8nkVasxUALps0nIlQ;_ylu=X3oDMTByZ2N0cmxpBHNlYwNzcgRzbGsDdmlkBHZ0aWQDBGdwb3MDMg--?p=diy+zinc+plate&vid=3d81ad456130b58321c500e4971178c0&turl=https%3A%2F%2Ftse3.mm.bing.net%2Fth%3Fid%3DOVP.HWEi-oMDEMCVqaB9nBDk6QEsCo%26pid%3D15.1%26h%3D168%26w%3D300%26c%3D7%26rs%3D1&rurl=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DWy6u2kikAA4&tit=how+to+do+zinc+plating+of+metal+parts+for+corrosion+protection+diy+electroplating&c=1&h=168&w=300&l=223&sigr=11b67b60g&sigt=12h2cc5aa&sigi=12rk4mnog&age=1430883748&fr2=p%3As%2Cv%3Av&fr=yhs-ddc-linuxmint&hsimp=yhs-linuxmint&hspart=ddc&type=__alt__ddc_linuxmint_com&tt=b Quote
spazzz Posted December 29, 2017 Report Posted December 29, 2017 I just did this last summer. Power stop calipers, Akebono ACT1159 pads, Goodridge lines from ZZP (cheapest place) and Raybestos 580403 advanced technology rotors. Stops great and stops great in cold. Quote
Imp558 Posted December 30, 2017 Report Posted December 30, 2017 Zinc is actually really easy to plate at home with. I got geared up to do it but haven't had time to experiment with it. https://video.search.yahoo.com/video/play;_ylt=AwrDQ2p8nkVasxUALps0nIlQ;_ylu=X3oDMTByZ2N0cmxpBHNlYwNzcgRzbGsDdmlkBHZ0aWQDBGdwb3MDMg--?p=diy+zinc+plate&vid=3d81ad456130b58321c500e4971178c0&turl=https%3A%2F%2Ftse3.mm.bing.net%2Fth%3Fid%3DOVP.HWEi-oMDEMCVqaB9nBDk6QEsCo%26pid%3D15.1%26h%3D168%26w%3D300%26c%3D7%26rs%3D1&rurl=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DWy6u2kikAA4&tit=how+to+do+zinc+plating+of+metal+parts+for+corrosion+protection+diy+electroplating&c=1&h=168&w=300&l=223&sigr=11b67b60g&sigt=12h2cc5aa&sigi=12rk4mnog&age=1430883748&fr2=p%3As%2Cv%3Av&fr=yhs-ddc-linuxmint&hsimp=yhs-linuxmint&hspart=ddc&type=__alt__ddc_linuxmint_com&tt=b Re-watched that link and the guy is bullshit. Not to say it's fake, just this guy. Essentially it's a chemical like Vinegar mixed with sugar and just a couple small batteries or a variable power supply. I got some zinc a while back to get started with this so when that finally happens I'll post instructions on what worked best and I'll leave some stuff outside to test it for rustproofing. Nas Escobar 1 Quote
MiriV Posted January 19, 2018 Report Posted January 19, 2018 I've been using HPS Hawk pads and was very happy with them, especially with the 06+ Impala calipers and ACDelco rotors. R1 slotted rotors I had before worked great for stock brakes with HPS pads but the paint they use wore off very fast. Quote
Grandprix1 Posted January 21, 2018 Report Posted January 21, 2018 I won't run a ceremic pad....Why not? Quote
Imp558 Posted January 21, 2018 Report Posted January 21, 2018 I don't like them either. Last yearish I picked up the best Semi-Metallic pads from Autozone on my way to the shop in the SSEI. Got there and raised the car, removed both front wheels, broke all the bolts free while the brakes cooled down. Then I removed a caliper and opened the box to find I WON! There was a note about being upgraded to ceramic pads for free! Put the car back together and drove back to the parts store to return them for a losing set. Quote
Grandprix1 Posted January 21, 2018 Report Posted January 21, 2018 I don't like them either. Last yearish I picked up the best Semi-Metallic pads from Autozone on my way to the shop in the SSEI. Got there and raised the car, removed both front wheels, broke all the bolts free while the brakes cooled down. Then I removed a caliper and opened the box to find I WON! There was a note about being upgraded to ceramic pads for free! Put the car back together and drove back to the parts store to return them for a losing set. why don't you like ceramic pads? Imp558 1 Quote
Imp558 Posted January 21, 2018 Report Posted January 21, 2018 why don't you like ceramic pads? They eat rotors faster Quote
Galaxie500XL Posted January 21, 2018 Report Posted January 21, 2018 In my experience, ceramics don’t do nearly as well in braking as semi metallic. Quote
Imp558 Posted January 21, 2018 Report Posted January 21, 2018 I always run a middle of the road name brand Semi. Years ago I got a set from Rockauto, put them on the Regal and recycled the box. I remembered them as being red in color but when I removed them they were actually green. Looking back I wish I'd kept the box safe, those pads worked great and still had enough material to pass PA safety inspection 3 years later when I replaced them, I could have run another year if I wanted. I would love to know what brand they were. Quote
Grandprix1 Posted January 21, 2018 Report Posted January 21, 2018 Ah ok. That’s what I’ve got on my car is ceramic. They work amazing. Bite hard. I’ll try some semi metallic when they need replaced Sent from my iPhone using Tapatalk Quote
Imp558 Posted January 21, 2018 Report Posted January 21, 2018 I should have been more specific, ceramic didn't grind away like full metallic pads but the one time I tried them a rotor warped and I didn't see a good reason for it. Semi pads have warped rotors for me too but I have to be driving in the mountains or something. Quote
55trucker Posted January 21, 2018 Report Posted January 21, 2018 Semi metallic pads will bite harder/quicker in a sudden cold (as in cold brake pad) panic stop, the ceramic pad will need to warm up to get into the *sweet spot* where it starts to delivers. That amount of time could be the difference between you hitting or not hitting the vehicle in front of you that you may be following too close to. The friction rating of most pads is generally an FF rating, that means the pad has the same cold friction rating performance as the pad will do in it's hot temp performance. If the rating is say EF that means the pads has a less effective cold performance than the pad will do in it's hot performance. The higher the friction rating the more bite the pad has & better stopping power ability, plus less fade. http://faculty.ccbcmd.edu/~smacadof/DOTPadCodes.htm Galaxie500XL and Imp558 2 Quote
l67ss Posted January 22, 2018 Report Posted January 22, 2018 Way I look at it. Any time heat is produced something has to wear. If the pads don't the rotor will. And my old ceremics stopped like I had worn pads Quote
