3800 Alternator relocation.
So as I lay awake last night wishing I could sleep it dawned on me that the concept of relocating the alt to the A/C compressor location is filled with benefits and not a single drawback serious that I could think of.
Pros:
Charge wire like 1' long instead of running all the way through the entire engine harness.
Alternator down in a cool location instead of up high in the heat.
Can remove the big stupid alternator bracket thus shaving weight, improving aesthetics, and eliminating the plastic elbows.
Get rid of hokey A/C compressor bypass pulley
Cons:
additional mount needs to be cobbled for an idler and tensioner, or really just a tensioner.
Need to devise a method of attaching heater lines to engine (possibly thread the holes in the timing cover and intake with pipe taps)
Anything I'm not thinking of? I'm sure it's been done.
Never seen it done. I upgraded to the cs144 which has an external fan and just ran 0 gauge. Cool idea though! I can't imagine not having ac though! Lol
You'd still need the elbows and belt tensioner though.
I live in a frozen wasteland and I have low blood pressure, it's never truly too hot for me.
Interesting thought though with the CS144, that would be a good opportunity to upgrade. When I get a chance I want to take a set of coolant elbows and dig through my pipe tap set to see how close they are.
I have access to a TIG but it may be a problem welding aluminum to cast aluminum.
I would personally love to see this project!
It's my 1995 GS. a thing happened where I was ready to lay my 1996 Regal sedan up for the winter and really build the snot out of it and some broad rear-ended me and totaled it. I imported the GS and have until May to get it ready for autocross.
For now I'm doing custom coilovers and a really mild L67/4T65 swap over the winter to get it race ready.
The next engine we're working on will be something a lot more sick with a 4T80 if all goes well.
ithurtz did it
Alright Scotty, it's up to you to convert him! Lol
GPF goes bonkers so everyone else flies all over lol.
so here goes. I cammed, did heads over the summer, did altlernator relocated, coil pack on firewall, coolant elbow delete. Slowly working on dog bone delete.
Had my  brother make the bracket, its just 1/2" steel bolted directly to the block, then the alt to that. I am M90 delete so it runs on the inner belt.
35807500045_601ed97f71_c.jpg20170708_202556 by Corey S, on Flickr
PLaying with where a tensioner could go
35553321831_1299d39b43_c.jpg20170701_153003 by Corey S, on Flickr
Coil pack relocate you can see it fine from above
36871229911_50b4086850_c.jpg20170903_143927 by Corey S, on Flickr
You just have to take apart the loom and bring the wire down below, I did zero wire cutting.
36093962084_e6f36fee31_c.jpg20170830_154734 by Corey S, on Flickr
36531937550_8518eb4b65_c.jpg20170830_160021 by Corey S, on Flickr
36871379361_8e35b51f09_c.jpg20170903_143544 by Corey S, on Flickr
To keep heat to the car the lim and timing cover was tapped. The lim I think was 3/4? I forget". The cover I forget but someone on the internet said a certain size well that was way to thin as seen in the pic and actually cracked it. Brother tigged it, and retapped, all is well.
34280692564_8e4b1dd6a2_c.jpg20170605_174114 by Corey S, on Flickr
35009309440_e3735bd4c0_c.jpg20170618_144702 by Corey S, on Flickr
36871378091_a5472f4073_c.jpg20170903_143520 by Corey S, on Flickr
I used the m90 tensioner and swapped pulleys with the ac delete bracket. So far I notice the tensioner is being pulled from the top down to the side a little little bit. No additional belt wear, but it has me watching it and thinking of a way to stop it from being pulled on so much.
  • Like 3
Coilovers all around or just the rear? I need help making the rear ones, specifically the part number for the strut mount. My understanding is that it has to be a specific one so you can put the bushing on so the spring has a place to rest.
All 4, my plates are RRRI (Jarek's gig) and my front spindles are from a second Gen.
