Compufreek Posted December 2, 2003 Report Posted December 2, 2003 I have recently rebuilt my top end in my 95 GP 3100 and I'm now getting alot of chatter out of the valve train. I tightened them to the correct torque spec and everything so I am stumped. The only things that are different are the new gasket kit and the fact that I shaved the heads down .015 to help raise the compression a little. Other than the noise everything else is running great. Anybody got any ideas? Quote
PaPaPooh Posted December 2, 2003 Report Posted December 2, 2003 well im not sure about this but what octane you running threw it? maybe trying a higher octane to see if it goes away? good luck Quote
Compufreek Posted December 2, 2003 Author Report Posted December 2, 2003 Well I did run 93 for the first time out but I'm now running 89. This didn't make any differnece it is not pinging it is definately valve train chatter, you can hear them all moving perfect but making a tapping noise...all of them. Quote
PaPaPooh Posted December 2, 2003 Report Posted December 2, 2003 hrm i wouldn't know i guess i could have asked if it was pinging :oops: Quote
lilloon Posted December 3, 2003 Report Posted December 3, 2003 when u had the heads shaved, did you also compenate by getting puchrods that are the same amount shorter? when you mill heads, and changed nothing else, the pushrods will effectivly be pushing farther up on the rocker arms which may not be able to handle that minimal difference. Quote
4spdz34 Posted December 3, 2003 Report Posted December 3, 2003 its not pushrods. either the hydraulic lifter or the rocker arm would adjust that. it sound like your vavles aren't adjusted correctly Quote
Compufreek Posted December 3, 2003 Author Report Posted December 3, 2003 How do you adjust the valves? There is nothing but springs and retainers holding the valves to the springs. Quote
Dan94Z34 Posted December 3, 2003 Report Posted December 3, 2003 The valves are not adjustable like a v8's. When you install the push rod and rocker arms, you torque the rocker nuts to 18lbs and thats it. Quote
Compufreek Posted December 4, 2003 Author Report Posted December 4, 2003 Yeah everything is torqued correctly and the pushrods are in the right place. I took the front valve cover off and ran the motor for a while trying to listen to where the noise is coming from but it really doesn't seem to be the valves, rocker, or pushrods. I think it may be a lifter, could that make it sound like a fricken sewing machine, LOL, cause that is what it sounds like. Quote
89oldscutlass Posted December 4, 2003 Report Posted December 4, 2003 Yes a collapsed lifter will make it sound like a sewing machine. Quote
Compufreek Posted December 4, 2003 Author Report Posted December 4, 2003 Well everything was fine before could the assembly grease or coilant/oil gel be clogging it? If that is the case would flushing the motor and running a slightly heavier oil in maybe help pump it up? Quote
