Performace Chip for a 94?
Is there a chip out there for a 94 z34? I have heard there is and there isn't. Whitch is true?
Yes, according to these websites, there are DOHC Memcals / re-flashed ECMs available...
* http://www.eperfpro.com/
* http://www.fastchip.com/
* http://www.hypertech-inc.com/
* http://www.jetchip.com/
* http://www.superchips.com
However, the debate is wether it's worth spending a few hundred dollars and seeing decent results.
I say ask a ton of questions to the dealers and grab that sounds the best preformer to you.
- Erik
I took a chance and am buying a used one from a guy at mymonte.com and i get a doa warranty so if it dostn work he will give me my money back.
its a therm-master from hypertech and i will let you know how it works out.
Thanks man, I would appricate it a lot :) .
No problem.
Here is my results with the Hypertech chip. Now running 93 octane i pulled a 15.25 at 95.5mph with gtech and 6.88 0-60mph time(one pass only). This measurement was taken with G-tech tonight. temp was 45degrees outside. Road is 99% flat and strait so the results were pretty accurate
I can say for a fact that my lowerend torque as improved! The chip claims a 1degree advance timing and slightly bumped rev limiter and fans come on earlier. I seen about 50-100rpm higher then stock chip. And my therm is stuck open so i probably wont see the fans come on tanytime soon aslong as its cold out. I dont know as of yet where my fuel shutoff if changed.
main result is a noticable difference in Torque expecialy when shifting, also possible due to higher shift points.
i hope this has helped some.. the chip was made for a 95 Monte carlo 3.4dohc and its in my Lumina 3.4dohc. works fine :)
kool man, that helps out. Im doing computer, intake, and exhaust upgrades to the car this summer.
