02 Intrigue Dashboard Lights
Are there any #194 twist sockets and #PC74 twist sockets that can be purchased to fit the intrigue gauge panel. I want to convert over to LED's and would like to find the correct sockets to fit the LED bulbs before tearing it all apart.
Any help would be appreciated!
Also gonna watch this cause I’d like to do the same. It’s been done I just dk what bulbs to use.
Sent from my iPhone using Tapatalk
Usually a 194 led in the twist socket fixes that issue. I haven't seen twist sockets with the bulb ready to go
Are these just remove from the twist socket and replace? Or are the original bulbs soldered into the socket(s)?
Thanks!
I know the original bulbs just twist out. But like Nas said I have yet to see an LED version of those.
Thanks!
Remove twist socket, pull 193 bulb out, then put in the led bulb. If it doesn't light up, you have to flip the twist socket 180.
Also, the cluster have gel behind them to give them that aqua look. Pure white will look ice blue.
