ManicMechanic Posted February 7, 2024 Report Posted February 7, 2024 46 minutes ago, cjc said: Just found this site while looking for carpet to fit my 93 vert, has anybody determined of a coupe will work and with how trouble. Coupe will work fine. These cars were coupes converted in to convertibles. Quote
rich_e777 Posted March 15, 2024 Report Posted March 15, 2024 (edited) Tis the weekend project, I`m removing the Vert carpet first right now. I`ll have them out tomorrow and will get some measurements and pics. So far the difference I see is where the carpet ends at. On the coupe the carpet goes all the way beneath the rear seat and into the trunk, on the convertible the carpet is trimmed to end under the rear seat and a black insulation pad carries on up the welded bracing for the convertible top. Edited March 15, 2024 by rich_e777 Quote
rich_e777 Posted March 17, 2024 Report Posted March 17, 2024 Ok lets start with the backseat area, thats as far as I am with yard work pressing. More to come tomorrow and will get into the `94 coupe for comparison. Here is what it looks like underneath. This is a `95 and other than a cosmetic difference in the trim, it should be about the same for all convertible Cutlass Supremes. I have not cleaned it up yet nor looked closer at the rust spots but nothing jumped out as alarming just yet. You can see where the carpet is just trimmed to fit around the rear seat belt bolts. Use the bolts to make a line as to where to end the carpet at, the rear insulation pad overlaps the carpet by a few inches. 94 olds vert 1 Quote
rich_e777 Posted March 17, 2024 Report Posted March 17, 2024 There seems to be a brace added that might affect the way the coupe carpet lays across the rear seat hump. The bolt provision for the rear seat is just above my hand for reference. There may be some other additions like this in the front. Will update again tomorrow. I dont think the coupes have this reinforcement piece here. Quote
cjc Posted March 19, 2024 Report Posted March 19, 2024 Very Curious as to how this turns out, If the only difference is in fact the rear floor reinforcement at the rear seat then that should be a win! Curious as to what else you find in the front. rich_e777 1 Quote
rich_e777 Posted March 20, 2024 Report Posted March 20, 2024 I`ll get back to it in the next few days with some more pics for the front. Ive read where there could be some reinforcement on the inside rocker panel area. If its a similar bulge then that might make the coupe carpet not wide enough to fit over it. I`m also going to try and swap carpets between the two models once there both out. Quote
rich_e777 Posted May 30, 2024 Report Posted May 30, 2024 (edited) Ha! I knew there was something I was forgetting. Yes in fact there is indeed an update... Ive not seen any differences in the carpets other than the rear area I posted earlier about. Ive got the convertible carpet removed completely and have been deep cleaning. I dont see any structural differences in the floor pan layout between the coupe and convertible until you get to just behind the rear seats. Life events are holding me up ordering the carpets right now. But when I do I personally will be ordering two identical slate grey carpets from RockAuto for a 1994 Cutlass Supreme and trimming one to fit my 1995 convertible. Edited May 30, 2024 by rich_e777 94 olds vert 1 Quote
Ric Posted June 4, 2024 Report Posted June 4, 2024 Thanks for your extensive input on this subject, I'll continue to follow your updates. I also just started a new question regarding rocker panel reenforcement strips for my '93 convertible. If you happen to have any thoughts on that too. Thanks again. Quote
Ric Posted April 3 Report Posted April 3 Did the final application of the coupe carpeting work ok in the convertible? I still need to improve mine and would like to buy new soon. Quote
94 olds vert Posted April 3 Report Posted April 3 (edited) 56 minutes ago, Ric said: Did the final application of the coupe carpeting work ok in the convertible? I still need to improve mine and would like to buy new soon. Edited April 3 by 94 olds vert Quote
Ric Posted Monday at 04:33 PM Report Posted Monday at 04:33 PM Hi, I'm hoping for a final answer also. Please reply when you have chance. Thanks rich_e777 1 Quote
rich_e777 Posted Tuesday at 02:41 AM Report Posted Tuesday at 02:41 AM I know, I know this is taking forever. Much work remains before we are ready to announce the success in the team's ability to not accomplish anything. I didnt see a question about reinforcements but they are indeed there, the VIN number is on the drivers side. They jut in a bit on both sides at the rocker panels so the coupe carpet would be a bit wide in this section. I`m confident it would work, I just dont have the extra $400 for the mass backed carpet I want in this bear market! I`m working on getting a donor coupe carpet in the Vert now and seeing how much and wear it needs to be trimmed. If I cannot update this week then this weekend. 94 olds vert 1 Quote
rich_e777 Posted Wednesday at 11:05 PM Report Posted Wednesday at 11:05 PM I attempted at least 6 videos but I suck at making them. I don't even know what I was trying to say. I`m 100% convinced that the coupe carpet is trimmed into place as it was being installed. The Vert carpet has all the signs around the edge were it was cut with a carpet knife while the coupe carpet has straight edges from the machine that produced it. Vert Coupe I lined them up as best could be using the drivers side pad and a straight edge. Aside from the larger hole for the center console I could not find a difference accept around the edges where it had been cut. The Coupe carpet has nice smooth edges while the Vert carpet is fraying in the places a knife cut it. 94 olds vert 1 Quote
rich_e777 Posted Wednesday at 11:16 PM Report Posted Wednesday at 11:16 PM Now how about some actual measurements? Did what I could, where I thought I should. Found a few things I will do my best to articulate. Because of the rear seat reinforcement on the Verts... It makes this measurement about 1 1/2 inches shorter when measuring to the very peak of that hump than on the coupe. That will affect the way the carpet lays as well as... 94 olds vert 1 Quote
rich_e777 Posted Wednesday at 11:20 PM Report Posted Wednesday at 11:20 PM (edited) When measuring across from clip to clip... All 3 on the coupe are 55" on the money, On the Vert they are all 54 1/2, this will also make the carpet lay funny unless trimmed. Edited Wednesday at 11:31 PM by rich_e777 Quote
