cutty collector Posted September 8, 2017 Report Posted September 8, 2017 been looking for some replacement carpeting for my 93 vert .Nobody sells a carpet for these what is the difference between a 2 dr coupe and a convertible carpet can it be made to work and if so where is the best place to buy Quote
MemphisMan Posted September 8, 2017 Report Posted September 8, 2017 I've been wondering about this too. I would think that the coupe carpet would work seeing as how they started off as coupes. Maybe the carpet was changed when they went to get converted, but I doubt it. I don't know for sure though. Quote
Imp558 Posted September 8, 2017 Report Posted September 8, 2017 Rockauto lists it. They say 2 & 4dr, exc convertible. I can't imagine why a 2dr shell would be any different unless there was additional bracing or something. Perhaps it isn't in the fit but in the material? Mold resistant or more sound deadening? Quote
rich_e777 Posted September 8, 2017 Report Posted September 8, 2017 Just from removing my coupe carpeting I think it has a different shape around the back seating area. The coupe carpet runs underneath the rear seats and sort of goes into the trunk area. The on the vert the carpet shape would have to be different in that area because of the top. Coupe carpeting should be roughly the same shape but you might have to trim up the rear portion of it. Nas Escobar 1 Quote
cutty collector Posted September 14, 2017 Author Report Posted September 14, 2017 I suppose I will have to contact the manufacturer if its too big due to going under the seat you would think it would be trim to fit? Quote
rich_e777 Posted September 14, 2017 Report Posted September 14, 2017 (edited) The only difference between the coupe and the convertible interior was the addition of a top. Because of where the top sits the coupe carpet cannot pass through into the trunk. If that squared section was trimmed off under the rear seats to me it would fit the convertible. Ive got a coupe and Vert and both could use some new carpet so I`ll probably be doing the same job soon. Seat belt holes are in the same place, same brass clips holding the carpet around rocker panel area, center consoles are interchangeable between older style trim and the 1995 re design, and several members have swapped from a rear bench seat to the dual bucket setup and Ive never read a fitment issue. My scientific wild ass guess is yes a coupe carpet can be trimmed to fit a convertible. Good luck getting the seats out, you really want to triple check the star bit socket is indeed the correct size for the seats mounting bolts, other than that its remotely easy by yourself. Edited September 14, 2017 by rich_e777 Quote
jmjp5055 Posted February 3, 2018 Report Posted February 3, 2018 I had bought front floor mats custom fit for my 94 and the passenger side mat didn’t fit right after a little back and forth they sent a new set that was a fit They said that the pattern used was for a coupe, something about the convertible passenger side floor pan is different. Sent from my iPhone using Tapatalk Quote
rich_e777 Posted January 4, 2019 Report Posted January 4, 2019 So i contacted ACC about carpeting for W-body convertibles and actually got a phone call instead of an email. Aside from the rear seat being different like I mentioned above there is also a difference about the rocker panels between the two models. They didnt have the specifics about why they were different but I`m inclined to find out this weekend. Quote
pshojo Posted January 6, 2019 Report Posted January 6, 2019 Wonder if they would develop set for us, and how many carpets would they need up front to sell. I’d want one Quote
rich_e777 Posted January 7, 2019 Report Posted January 7, 2019 I did some measuring and swapped floor mats from the vert to coupe and vice versa and everything looks the same. I cannot tell there is a different in the rocker panel of floor board area. I`m tempted to just buy a coupe carpet and see how it fits in the Vert. Quote
DavidHowell3633 Posted January 25, 2019 Report Posted January 25, 2019 I used a coupe carpet for my convertible. Just overlay the coupe carpet with your convertible carpet and use the convertible one on top to guide you for cutting out the holes for the center console. Quote
Ric Posted December 24, 2019 Report Posted December 24, 2019 I just cam across this string after post a similar question. The string is a couple years old but has it ever been decided if the coupe carpet will indeed work in a convertible? How much trouble is it to make one work? Quote
rich_e777 Posted December 27, 2019 Report Posted December 27, 2019 I`m ordering a 1994 coupe carpet next payday and will attempt to put it in a 1995 Convertible to get a solid answer. Quote
Ric Posted May 8, 2020 Report Posted May 8, 2020 Did you have any luck with the coupe carpeting? I'd like to get carpeting for my '93 convertible. Quote
Human Posted May 12, 2020 Report Posted May 12, 2020 Yes, inquiring minds would like to know. My convertible's carpet is faded and has a hole on the driver's side. For what it's worth, I don't think there's any appreciable difference in the front floorboards of the coupe and convertible. My '95 vert didn't have any floor mats in it when I got it but I had the front mats from my '91 coupe sitting in my barn. I cleaned them up and they're a perfect fit. The funny thing is the carpet in my '91 coupe was a medium gray and the interior of my convertible is graphite but the carpet in the front floorboard of the convertible is faded to the point that it is a near perfect match for the lighter floor mats. The rear floor mats I have in it are from the '95 Aurora I used to have. It also had a graphite interior and the carpet in the rear of the vert is just enough less faded than in the front so they're a reasonably good match back there. Quote
rich_e777 Posted May 12, 2020 Report Posted May 12, 2020 I got involved up under the car a bit more than expected and this sort of got pushed to the side. I have seen some differences in floor mat options between the coupe and Vert showing the rocker panel area to center "hump" maybe different so the formed bends in the carpet maybe somewhat off. I will still try it out, just taking a bit longer to get to interior stuff when its on jackstands. Quote
Ric Posted June 24, 2020 Report Posted June 24, 2020 Thanks. I don’t get on this site as much as I maybe should (so I’m just now replying) but I’m still very anxious to hear what you find out. Quote
Ric Posted April 5, 2021 Report Posted April 5, 2021 Has anyone figured out how much trouble it is to make coupe carpeting work in a '93 convertible yet? Quote
94 olds vert Posted April 5, 2021 Report Posted April 5, 2021 1 hour ago, Ric said: Has anyone figured out how much trouble it is to make coupe carpeting work in a '93 convertible yet? Based on what Crazy K said the carpet is not interchangeable to a convertible. The two cars are different, and I'm not sure if it can be done and still look good. Quote
Ric Posted April 8, 2023 Report Posted April 8, 2023 I'm checking back in again for advise to find replacement carpet for my '93 vert. Anybody have ideas? Quote
94 olds vert Posted April 8, 2023 Report Posted April 8, 2023 3 hours ago, Ric said: I'm checking back in again for advise to find replacement carpet for my '93 vert. Anybody have ideas? This is the only carpet I could find for sale. I'm not sure how well it would fit. It might be worthwhile to contact this company and get some information. https://www.ebay.com/itm/195538997920?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20220705100511%26meid%3D7f5a5fed911f4d1bada02c2a2b5d3bd8%26pid%3D101524%26rk%3D1%26rkt%3D1%26itm%3D195538997920%26pmt%3D1%26noa%3D1%26pg%3D2380057%26algv%3DRecentlyViewedItemsV2%26brand%3DNewark+Auto+Products&_trksid=p2380057.c101524.m146925&_trkparms=pageci%3Aa507aa2a-d63f-11ed-8589-0efa92baf579|parentrq%3A623de3371870aa70d8b9c04effffef8e|iid%3A1 Quote
rich_e777 Posted April 8, 2023 Report Posted April 8, 2023 Its only been 2 years, i should probably get on this. I got side tracked with other stuff, I need a decent dry weekend to pull both carpets and get some measurements. pshojo 1 Quote
Ric Posted April 25, 2023 Report Posted April 25, 2023 I understand. Let me know, thanks! rich_e777 1 Quote
Ric Posted April 25, 2023 Report Posted April 25, 2023 Thanks [94 olds vert], I did see that listing but I'm a little apprehensive to give it a shot without more input or research. I'm also going to check some bone yards to see if I could get luck with second-hand convertible carpet. Maybe I can find something that when shampooed is better than what I have now. Quote
cjc Posted February 7, 2024 Report Posted February 7, 2024 Just found this site while looking for carpet to fit my 93 vert, has anybody determined of a coupe will work and with how trouble. rich_e777 1 Quote
