02 Monte Lock Problems
I'm diagnosing an interesting door lock problem this evening, the locks will unlock with the switch but not lock. Since it's routed through the BCM I'm thinking it's a decision being made by the BCM.
The first thing I want to look at is the parity of the "Key in Ignition" input, I believe if the BCM thinks the key is in the ignition it will not want to lock the doors.
Can anybody think of anything else? Should be the same as any other second Gen...
So it will lock with the remote but not physically moving the lock? I know if they key is in the ignition and you press the lock button with the door open it will not let you do it.
Sent from my iPhone using Tapatalk
