stuhrling Posted August 29, 2017 Report Posted August 29, 2017 I want to make a backup PCM for a 2002 Oldsmobile Intrigue. If I were to purchase a used one would it be possible to have it flashed with the current VIN so as to make it like the original that is currently in the vehicle (Plug & Play)? Would it still have to go through the relearning process for the crank sensor or any of the other security measures? Thanks! Quote
Imp558 Posted August 29, 2017 Report Posted August 29, 2017 anybody who can program a PCM could read yours and then burn the file into another PCM that has the same service number. From that point you would need to do a case relearn and relearn the Anti-Theft were you to change it.in theory is someone where to program a new computer for you you could have them simply disable the Anti-Theft Quote
