pshojo Posted August 15, 2017 Report Posted August 15, 2017 I believe I have a sticky, or lifter that drains down sometimes. It makes a little noise 1/2 the time on start up, then goes away after a block or two. Any suggestions? I'm thinking running some transmission oil through for 5-10 minutes before oil change then Marvel Mystery? Thoughts? Quote
94 olds vert Posted August 15, 2017 Report Posted August 15, 2017 I have tried the transmission fluid in my oil on my 3.4l dohc. It helped quite down that lifter tick for a little while Quote
digitaloutsider Posted August 15, 2017 Report Posted August 15, 2017 If it's truly a sticking lifter, just dump the MMO in there now and run it for a while (could honestly run with it for a full OCI). Wouldn't bother with the transmission fluid. rich_e777 1 Quote
Imp558 Posted August 15, 2017 Report Posted August 15, 2017 Tranny fluid tends to coagulate when it gets hot. I'd be more prone to try mmo or a slick 50 type product that forms smaller molecular chains in an attempt to penetrate and lube the lifter. Stuff that's supposed to quiet an engine is usually thick. Quote
Schurkey Posted August 16, 2017 Report Posted August 16, 2017 I believe I have a sticky, or lifter that drains down sometimes. It makes a little noise 1/2 the time on start up, then goes away after a block or two. Any suggestions? I'm thinking running some transmission oil through for 5-10 minutes before oil change then Marvel Mystery? Thoughts? WHAT ENGINE??? WHAT CAR? The 3.4L DOHC in the early W-body had a service bulletin about noisy lifters when cold. http://www.60degreev6.com/vb5/articles/-1991-1997-dohc-aa/424720-lq1-service-bulletin-57-61-09-lifter-tick-cold Having performed the modification on one of my own cars, I think it's a dodge to avoid dealing with piston slap. Trans fluid MIGHT work. MMO MIGHT work. Seafoam MIGHT work. Gunk Engine Flush MIGHT work. Thirty other dissolve-and-flush-the-crud-in-your-engine products MIGHT work. My guess is that none of them will make any difference. But you won't know until you try. Quote
pshojo Posted August 17, 2017 Author Report Posted August 17, 2017 Can you do this mod 3.4 on the car? the funny thing is my 3.8 does this too only from time to time. Quote
Schurkey Posted August 27, 2017 Report Posted August 27, 2017 Can you do this mod 3.4 on the car? Yes, but it's way less fun. Quote
