Brian02GPGT Posted July 12, 2017 Report Posted July 12, 2017 Can someone please help me out with how to move my DRLs from the headlights to the fog lights? Those darn DRLs are on all the time, and it would look better if I could run with the dogs and parking lamps on. Plus it wouldn't burn out expensive headlight bulbs so quickly. I'm excellent with electrical work, so maybe just a schematic? I found a link on here, but when I click it my phone warns me if I proceed the phone will contract all types of diseases. Thanks for the help!! Quote
Brian02GPGT Posted July 12, 2017 Author Report Posted July 12, 2017 I like the safety aspect. I live in sunny Florida and it is like heaven waiting room around here. I need all the help I can get to make sure Aunt Ethel doesn't pull out in front of me because she had on the sunglasses she got after her glaucoma surgery(so stylish) and didn't notice me. Lol 94 olds vert 1 Quote
55trucker Posted July 12, 2017 Report Posted July 12, 2017 You basically want to do the same thing that I have started. Being Canadian my 1991 car has DRL's as well, I altered the wiring to remove the circuit from the headlights as I am running HID's on the lows. Yet to be completed is running the circuit to put the DRL's on the forward parking lights. This involves going into the harness and running the conductor from the output side of the DRL module to the forward park lights, also to go in there will be a diode to prevent any current feeding back which would power up all of the other park lights in the same circuit. This my wiring schematic for my 91, I made the cut at the output side of the DRL module on terminal F wire 2 YEL which goes to a splice (S275) and then onto the dimmer/flasher switch & then on to the low beams side of the headlights. Your circuit wiring won't be quite the same but should be similar in it's layout. Quote
