1989 Pontiac Se Posted May 30, 2017 Report Posted May 30, 2017 I have overheating problems back pressure in the radiator water in the motor but it doesnt smoke starts up runs no problem. What does this mean? And if my heads are gone whats the best advice on gettinf this car nack in the road? Sent from my LGMS210 using Tapatalk Quote
Imp558 Posted May 30, 2017 Report Posted May 30, 2017 Pull the plugs and inspect them. Look for evidence that there's water in the cylinder. Also, look for bubbles in the coolant. You may yet have a failed water pump or thermostat. Don't jump the gun. Galaxie500XL and 1989 Pontiac Se 2 Quote
dogginred90 Posted May 31, 2017 Report Posted May 31, 2017 2.8 heads love to get hairline cracks at the spark plug holes. I had a couple sets all the same cracks in the same places. Exhaust gases entered the cooling passage and had overflow bottle boiling. I would guess the heads before the gaskets, but I may be wrong. Ask my wife and I am always wrong lol. 1989 Pontiac Se 1 Quote
1989 Pontiac Se Posted June 4, 2017 Author Report Posted June 4, 2017 Okay so i had new ones put in like two days and i drained the watery oil out of the motor and coolant from the radiator. Where do i start as far as diagnosing goes. Sent from my LGMS210 using Tapatalk Quote
Imp558 Posted June 4, 2017 Report Posted June 4, 2017 How do the plugs look? Are they all worn the same? 1989 Pontiac Se 1 Quote
1989 Pontiac Se Posted June 5, 2017 Author Report Posted June 5, 2017 Ill pull them and give you anither update. Thanks for checkin in. Sent from my LGMS210 using Tapatalk Quote
1989 Pontiac Se Posted June 5, 2017 Author Report Posted June 5, 2017 How do the plugs look? Are they all worn the same?Pulling plugs today. Sent from my LGMS210 using Tapatalk Quote
1989 Pontiac Se Posted June 6, 2017 Author Report Posted June 6, 2017 I pulled plugs cylinder 4 plug was wet i dried it off and turned car over same scenario only plug thats wet all other pkugs are worn evenly. Sent from my LGMS210 using Tapatalk Quote
1989 Pontiac Se Posted June 6, 2017 Author Report Posted June 6, 2017 Will the t code 3.1 from the 93-94 lumina be a direct swap? Sent from my LGMS210 using Tapatalk Quote
digitaloutsider Posted June 6, 2017 Report Posted June 6, 2017 Please do not make redundant posts. Merged with your other thread. Quote
1989 Pontiac Se Posted June 6, 2017 Author Report Posted June 6, 2017 Im not trying to be redundant i just want to know. If you dont know if you dont ask. Sent from my LGMS210 using Tapatalk Quote
Nas Escobar Posted June 6, 2017 Report Posted June 6, 2017 You have a couple threads basically asking "what can I put into my GP". It's not redundant, but I can see where he's coming from, especially after I told you in another thread that the LH0 would bolt right in where a LB6 resided. Engine VIN "T" is basically the LH0. 1989 Pontiac Se 1 Quote
1989 Pontiac Se Posted June 7, 2017 Author Report Posted June 7, 2017 Yeah me too but thanks alot really helpful imformation from you guys. Sent from my LGMS210 using Tapatalk Quote
