Noise after changing timing belt and all components.
Hello everyone. So over the weekend i finished swapping the timing belt and all components. I even changed the tensioner pulley that is driven by the accessory belt. Car runs good and does not over heat. However theres a strange noise coming from the belt area and i cant figure what it is. Any thought or suggestions on where to start. Thanks, Tony.
Spray a little wd40 on the tensioner and idlers aI bet it goes away.
  • Like 1
Ok i will try that. Thanks a ton. I was starting to think i screwed up somewhere down the line but the car runs fine.
Ok thanks will try that out.
I took off the serpentine belt and lubricated the pullyley. So far no noise. Hopefully that solves the issue.
It'll be back, Rockauto should have all the pulleys for cheap. I try to keep a whole set here so I never have to pay three times as much locally.
  • Like 1
WD40 did the trick. No more noise ☺
