Grandprix1's Top Swap parts list
While not exactly rare black gtp emblems are a Lil hard to find. I have mebbe three of the black ones and around 150 of the gray ones lol
IIRC, all of the badges from 99 or 00 up are black, I forget the year.  The only truly rare GTP badges are off the 2003s, which are squared off and not round.
Most of the 00+ I've seen were gray. I do have a set of square emblems
Yeah most I see are silver. I don't really like the squared off badges tbh.
Sent from my iPhone using Tapatalk
I've removed the quick disconnects off the fuel rail. Now how does one go about getting the line off the connection or do I need to buy new lines and connections
What??
Where the guy cut or broke the fuel lines off the fuel rail is connected to the quick disconnect that I removed off the fuel rail. Do my fuel lines just connect there with their weird connections that don't look anything like these or do I splice my lines onto the L67 fuel rail quick disconnects
You have two options: just connect the current fuel lines to the rail, despite the bends
or
Buy these and use them instead:
http://www.rockauto.com/en/parts/dorman,800057,fuel+line+connector,10149
http://www.rockauto.com/en/parts/dorman,800058,fuel+line+connector,10149
Good call, I totally forgot about the fuel lines having that 90 degree bend in them.
If I'm able to just connect my current fuel lines to the rail regardless of those 90 degree bends then that's what I'll do.
My only concern is the stress that's putting on the fuel lines.  Maybe someone else can chime in, but if it were my car, I'd do the straight quick connects.
Edit:  I bounced it off Chris and he just rotated the lines around and used them, and that car is still running around, so I guess it's probably OK.  I guess we'll play it by ear.  If it looks that bad, you can always put the straight connectors on later.
Yeah I agree with you on that one. But then how do we splice the new straight line connection into the current fuel rails? Do I need both of those connectors or just one of them? Ill add them to the parts list.
There is a brass barbed fitting inside that kit that connects the new straight thru line to your old line.
You need both.
You need both.
Ok I've added them to the list. Do I need 2 of each? For the 2 connections on the fuel rail
Do I need a different serpitine belt?
I also need to do rocker arm bolts as they are torque to yield
Now I know you can figure this one out yourself.
im going to go with no because nothing is changing on the drive line. The only thing that's changing is going to be adding supercharger stuff
There's an easy way you can confirm that to be true, on your phone right now.  The power of the Internet (and online parts catalogs)!
I wanted to get the proper lines when I did my L67 swap, but in the end I just rotated them around and they worked just fine. Over 100k miles on that swap now.
Also, Dorman does make a really nice nylon fuel line kit, that allows you to  cut and splice the lines but its quite expensive.
According to rock autos catalog the drive belts for both the NA and SC are the same part number meaning they are the same so I can just reuse my current belt
Do the 90* connectors turn on the line?
There ya go.
I linked to the sizes he needs earlier in the thread. $20 for both sides.
There ya go.
So I just need 1 of each? That's better then needed 2 for each side
