SleeperIntrigue Posted April 19, 2017 Report Posted April 19, 2017 Hello all. New to the forums here. Also new to W Bodies. Already posted in the introductions area. Heres the situation: Im planning to swap an L67 supercharged V6 into my 2002 Olds Intrigue. Ive heard of it being done a couple of times but theres just no information out there. What I am looking for and need help finding is a Pinout diagram for the bulkhead connector on the firewall of my car. Ive tried googling to no avail and any shop manual i find is $150+. I was hoping somebody here had a wiring diagram or something that can help me out. Thank in advanced everybody! Quote
SleeperIntrigue Posted April 19, 2017 Author Report Posted April 19, 2017 The Intrigue currently has the 3.5 DOHC "shortstar" engine. To my knowledge, it was the only engin offered in this car from 2000 on Quote
l67ss Posted April 19, 2017 Report Posted April 19, 2017 Should be able to use 98-99 intrigue engine harness for the swap Quote
SleeperIntrigue Posted April 19, 2017 Author Report Posted April 19, 2017 I thought about it and just wasnt too sure because I know the Intrigue never had the supercharged engine. I also didn't know if there were any differences for wiring from year to year. But ill definitely keep that in mind. Thanks! Quote
l67ss Posted April 19, 2017 Report Posted April 19, 2017 On the supercharge thing you don't really need a factory supercharged harness....it just has to be a 3800 harness. The only actual difference is the map plug which is easy to swap. Color coded the same and you just have to add a few inches to the wires with the new plug. I myself have an sc swapped 97 Monte and my particular body style Monte never came supercharged digitaloutsider 1 Quote
SleeperIntrigue Posted April 19, 2017 Author Report Posted April 19, 2017 Awesome man! Thats exactly what I needed to know. The only other question I have is: are there any differences between the 98-99 C100 bulk head and my 2002 bulkhead as far as wiring? I know physically they are the same. I just want to make sure things will work or I at least know what I have to do to make it work. Quote
l67ss Posted April 19, 2017 Report Posted April 19, 2017 From what I've been told the same model on gen 2 cars are plug in swap. Kinda ran into it on my friends 97 grand Prix I l67 swapped. 97 gps are gen 2 but got stuck with weird pcms and 4t60 trans. Also a Lil tip is reuse the trans mount bracket off your trans. Its aluminum and actually the same part they used on the 5.3 cars Quote
SleeperIntrigue Posted April 20, 2017 Author Report Posted April 20, 2017 Awesome! Thanks a ton for the info. Cant wait to get started. Itll be so much easier now that i know its plug and play Quote
SleeperIntrigue Posted April 20, 2017 Author Report Posted April 20, 2017 Also, while your here, do you have any clue about if I'll have to modify any CV shafts? Or can i just use some stockers out of a 3800 car? Quote
Imp558 Posted April 20, 2017 Report Posted April 20, 2017 There's a second plug to change, or add rather for the boost solenoid. The cv shafts have different splines but you can charge the tulips on the shafts IF you can find the right size. When you get to that point post and see if someone here has them. We will need a measurement on the diameter. Quote
l67ss Posted April 20, 2017 Report Posted April 20, 2017 Driver CV is the same. Gtp passenger CV is a direct swap. And I left out the boost solenoid Quote
SleeperIntrigue Posted April 20, 2017 Author Report Posted April 20, 2017 Thanks for the Rreplies, guys. Is the boost solenoid neccessary? Im guessing no simce L67SS omitted it Quote
Imp558 Posted April 20, 2017 Report Posted April 20, 2017 it's got to be a hell of a lot more fun when you want to idle. Quote
l67ss Posted April 20, 2017 Report Posted April 20, 2017 All the solenoid does is lock out boost in reverse and during active abs. Quote
SleeperIntrigue Posted April 20, 2017 Author Report Posted April 20, 2017 Ah okay. I'll wire it in just to be safe then. Im going for the least amount possible to go wrong haha. So supposedly my stock gauges and all the interior wiring should still work after the swap? Quote
Imp558 Posted April 20, 2017 Report Posted April 20, 2017 Cold start ups mine is open. The sound of the air rushing through it is awesome. Quote
l67ss Posted April 20, 2017 Report Posted April 20, 2017 My bbv still works without the solenoid Quote
