digitaloutsider Posted April 18, 2017 Report Posted April 18, 2017 Safely Modding Your 3800 For Dummies digitaloutsider - W-body.com - April 18, 2017 Overview: This guide is intended for 3800 (particularly the Supercharged Series II [L67] and Series III [L32]) owners who are new to modifying their car for performance. This document is not intended to be an all-encompassing how-to for running 11's. Within this guide, I will discuss how to safely, and rather inexpensively, modify your supercharged 3800 to pick up a few ponies as well as dispel some myths about the platform. Acknowledgements: The idea for this guide originated on GrandPrixForums in 2009 by Nick (blueguy), however, some parts of that guide have become outdated by losing various vendors, conducting better research, and finding betters ways of doing things. Much of Nick's guide is still relevant today and it's certainly worth the read when you have the time, OR if you want to go faster than the modifications in this guide allow for. Introduction: So you've decided to steal cable modify your 3800 car. Great choice! Whether you're looking to learn more about engines and performance or just want to make your way to the grocery store faster, the GM 3800 platform offers an easy and cost-effective starting point. When it debuted in 1996, the Series II 3800 offered class-leading supercharged performance. Fortunately or unfortunately, the rest of the world kept moving, and in the days of 300 horsepower minivans, 240 ponies doesn't seem as impressive anymore, especially considering we have a supercharger bolted on. Good thing we're only a few clicks away from a lot of extra power being delivered right to our door. I would like to layout a very specific caveat: The transmission. The GM 4T65E was used in all Supercharged 3800 applications from 1997 to 2007. It was also bolted to everything from 170 HP 3100s all the way up to 300 HP LS4 V8s with very little overall differences. This, of course, means that GM's bean counters were in full effect in regards to the design of this transmission, and there were cost cutting measures taken. The internals of the 4T65E bolted to your 3800 are largely no different than the ones in a base Buick Century. Towards that end, it's best to just accept now that the more you modify your car, the greater your risk of breaking your transmission are. Fortunately, if you're serious about going fast, high performance transmission builds can be purchased from vendors like Triple Edge Performance. I would recommend that one of your first modifications be a transmission cooler. I would also recommend the medium shift kit as outlined in this guide, or the TransGo shift kit. Before you mod: You need to fix everything wrong with your car before you modify it. You need to fix everything wrong with your car before you modify it. You need to fix everything wrong with your car before you modify it. You'd think that this guidance would be self-evident, but after being on the various W-body/3800 forums and Facebook groups over the last 15 years, I'm sorry to tell you that it is not. Before you change ANYTHING to alter the performance of your car, you need to be sure that it's in good working order. Let's be honest, the newest supercharged 3800 car is 10 years old now, the oldest is over 20.. most of them are going to be in various states of disrepair. You need to, at the very least, perform a basic tune-up and catch up on years of deferred maintenance. Nick actually outlined this very well in his original guide, so I will copy it mostly verbatim here. Start here: Lower intake manifold gaskets and coolant elbows if they haven't been done (if you aren't 100% sure, just do them). New spark plugs and wires. Oil change, preferably switch to synthetic and a quality filter. Fuel filter. Coolant Flush. There is no compelling reason to move away from Dexcool, don't bother doing it. Transmission fluid and filter. Dexron VI or Alison TES-389 compliant ONLY. Generally need ~7 quarts for a pan drop. 100k+ mile engines: Change the supercharger oil. Do not use ANYTHING other than the proper S/C oil from the dealer. S/C and Serpentine belts. Once all of that is taken care of, you can start to move into the next major step.. Scanning: The basis for everything we do with performance mods will center around scanning the car and knowing what's going on inside. If you don't have a scantool that can read Knock Retard, do not modify your car. It's as simple as that. I don't care what ZZP told you, I don't care what your buddy says, I don't care what some guy on Facebook posted; if you don't have a scantool that can read Knock Retard, do not modify your car. Knock Retard, or KR, happens when the PCM detects predetonation (knock) and pulls timing to prevent engine damage. Your goal is to have 0 degrees of KR all the time. People will tell you that there's a "safe level" of KR, and on a stock car, sure, there might be. But as you start increasing boost and power, even small amounts of KR can bring our old pal Chippy the Piston to visit. Like most things about this platform, it's cheap and easy to scan. If you own an Android phone or tablet, the lowest cost of entry is to buy a BAFX Bluetooth OBD-II adapter and Torque Pro. iOS users can purchase OBD Fusion, and the website lists all compatible adapters. Cheap Android devices are getting so inexpensive that you could probably pick one up from eBay and just keep it in the car all the time to use with Torque. If you've scanned and everything looks kosher, it's probably safe to start throwing some mods at the car. The basics: Intake. The first mod most owners do is an intake. And why wouldn't you? It's a great first step because it frees up a little power, but more importantly it sounds awesome. Supercharger whine is cooler than going fast, anyway. Really though, I'd start here. It's cheap. You don't need to spend hundreds of dollars on an intake, but I also don't recommend just plopping a cone on the end of the throttle body.For 99-05 L67, go buy 4" PVC pipe from Home Depot along with a cone air filter (for 97-98 L67, go buy the newer F-duct and do all the following stuff). Remove the factory airbox. Cut the PVC pipe to the proper length. You want to slide the pipe far enough in the F-duct (the rubber coupler that attaches to the throttle body) to bypass the accordion folds. Have the filter as far into the corner of the engine bay as you can so it gets the coolest air possible. You can get a PCM tray out of a 90's S-Series Blazer/Jimmy/whatever if you want to secure it to the car. I have used foam pipe wrap (like what goes around residential HVAC lines) to put around and under the PCM to prevent it from being banged around. For 04-07 L32 Grand Prix, the same pretty much applies, but you'll be attaching the pipe to the MAF tube. If you like to spend a lot of money, CAIs are available from various manufacturers including ZZP, Cold Air Inductions, and others. Exhaust. What goes in must come out, right? Unfortunately the stock exhaust, especially on the L67 cars, is awful. The front manifolds have casting artifacts throughout and the ports are often uneven in diameter. Things get worse once you leave the manifolds as the factory downpipe is double walled, which reduces the ID down to 2.5" and there's an insanely stupid "U-bend" in the pipe where the rear O2 sensor installs. GM removed their cranium from their anus and the L32 cars lack the U-bend, but still have the same 2.5" piping. Before ANY pulley drop, the factory downpipe should be removed. There are two ways to go about doing this: ZZP bolt-in downpipe. If you're keeping the stock catback (which is generally good to 300 WHP), select the 3" DP and 2.5" flange exit. If you're having an exhaust shop weld up a full 3" exhaust, select the 3" DP with 3" exit or exit flange depending on how you want it. Do not buy the 2.5" downpipe for a supercharged application. It's up to you whether or not you want to buy a catted version, but be aware that not having a cat will trigger a check engine lamp. The ZZP downpipe can be used standalone or mated to a.. ZZP Powerlog. ZZP offers two Powerlogs, one for the front, and one for the rear. Think of these as the most extreme form of ported exhaust manifolds you can buy, but better. If you're not going totally insane, a front Powerlog and downpipe is a great place to start. It removes both the restrictive front manifold and U-bend. You can reasonably expect to drop a couple of degrees in KR from these two alone. If you want to free the exhaust up more, ZZP also offers a rear Powerlog, and with both logs combined with the downpipe, you get a very reasonable facsimile to headers.. without the fitment issues. Yes, it's kind of pricy to do it this way, but it also just bolts together and works. Headers. Once upon a time, there were a lot of vendors peddling their own version of 3800 headers. You had SLP, Thrasher/TOGs, Pacesetters.. today the market is a lot smaller. Your primary players are ZZP, Speed Daddy, and OBX. First up, the ZZP headers. Downside: they're very expensive. Upside: they "just work" and fit, but for that price they ought to. The most popular headers available for the W-body/3800 are Speed Daddy headers off of eBay. The big upside? They're cheap and they're based on (ripped off) SLP's design. $210 for a full set of headers shipped right to your door. The downside is that they don't fit perfect for everybody. Some people, particularly Regal owners, get stuck having to find creative ways to bash the firewall into make the O2 sensor fit. Others run these with no problem at all. If you don't want to spend tons of cash on exhaust and don't mind working a little to make them perfect, the SD's are a great choice. Be sure to throw away every gasket and clamp in the box. Buy a better flange gasket and use band clamps. It's also likely that the flex section will blow out at some point. Replace it and it's good to go. The last major manufacturer is OBX. They're ripoff Pacesetters. Real Pacesetters were bad enough.. don't buy these. Thermostat. You're going to see a lot of people with a lot of opinions when it comes to thermostats. In my opinion, 160 degree t-stats are just too cold. You don't get any heat in the winter, and 2001+ cars will throw a check engine lamp for coolant temp under regulated temperature. Your best bet is a quality 180 degree thermostat, with a small hole drilled in it to make bleeding easier. Tune. One of the best ways to wake a car up and eliminate KR is to tune it. Factory tunes are conservative and are intended to make the car work in a wide variety of driving situations, no matter what weather, what time of year, what elevation, etc. Performance tunes are meant for going fast. Like most things we've talked about, you have a few options here: Canned Tune. Canned tunes, or "mail order" tunes are generic performance tunes that are provided to the customer via shipping a PCM (Powertrain Control Module) back and forth to the vendor. These are generally not tuned specifically for you and will never be as good as an in-car street or dyno tune. That being said, they can be a good place to start and might even make sense for someone who is going to stick with only minor mods. You can buy tunes from Overkill, INTENSE, and ZZP. Keep in mind that the PCM is really at the heart of your performance build.. I would certainly do your own research before you decide to buy from a vendor. Google is your friend and these cars are VERY well documented. Tuner. You've got two choices here, HPTuners or DHP. HPTuners is a full vehicle tuning and scanning suite that works on a LOT of different GM, Ford, and Chrysler vehicles, not just our 3800 cars. The base VCM Suite offers 8 vehicle credits, which is enough for 4 different 3800 cars. If you're serious about tuning, you probably can't go wrong with HPT.. unfortunately it's pricey: $500 for the standard version, $650 for the "professional" version. Supports up to 2007. DHP or Digital Horsepower/PowrTuner is a now-depreciated tuning and scanning suite. DHP debuted in the mid 2000's and was abandoned by 2011 or so. While that means there's no official support, it also means it has a relatively low cost of entry. You can usually find used DHP interfaces for around $250 in the various 3800/W-body classifieds. Combined with TinyTuner, DHP still offers a compelling selection of options and great 3800 tuning capabilities. 97-04 cars only. Pulley. There's a reason why this section is at the end. A pulley drop should never be your first modification. Yes, a smaller pulley means more boost, but more boost out of an M90 also means more heat. More heat means more knock. If you haven't done the proper supporting mods first, Chippy the Piston will be making a visit to your engine. Assuming you've got a strong running stock car, you've freed up the intake and exhaust, and you've scanned throughly ensuring you have no KR, you're safe to drop a pulley. Avoid the thought process where smaller pulley = moar better. That isn't true. With the right combination of tuning and supporting mods, a car with a bigger pulley can outperform one with a smaller pulley and no/poorly executed mods. You have two options for changing pulley sizes. You can buy either a press-on pulley, which requires a special tool remove AND install or an MPS hub. An MPS hub allows you to bolt on different pulleys with just the use of an allen wrench. If you plan on doing more mods in the future, an MPS hub is probably the best deal. You can buy them new from INTENSE and ZZP for about $100. Each MPS kit comes with one pulley. No matter whether you go with an MPS or Press-on, a SUPERCHARGER PULLEY REMOVAL TOOL MUST BE USED. DO NOT USE ANY OTHER TYPE OF PULLEY PULLER ON YOUR SUPERCHARGER. The following is a list of pulleys that are "generally regarded as safe" with the appropriate mods: Generation 3 M90 (L67): 3.6" pulley - A great starting point for a car with minimal mods, such as maybe just a downpipe and intake. 3.5" pulley - Good choice for an intake, front powerlog, and downpipe. 3.4" pulley - Consider the 3.4" if you're running an intake, full headers, and a tune. You should also consider a cooler spark plug, such as the Autolite 104. Generation V M90 (L32, 04+ GP): 3.6" pulley - The defacto "safe" L32 pulley if you don't have lots of modifications. You should at least have a 3" downpipe. Preferably a front Powerlog. 3.5" pulley - If you have headers (or F&R Plog + DP) and a tune, a 3.5" pulley can be a good fit for the L32 cars. 3.4" pulley - All of the above, plus 1.9 rockers. Advanced Modding considerations: As stated earlier in this guide, my primary goal is to give novice 3800 owners a good starting point to begin modifying their car. In my honest opinion, once you start dropping below 3.4" pulleys and headers, you really need to have a good mental grasp on the work that you're doing. At that point, you should NOT be relying on a guide to tell you how to mod your car. You need to understand tuning and be able to change your own PCM around without relying on canned tunes. That being said, I will BRIEFLY talk about a few of the more advanced modifications available to you once you feel more confident in your abilities. E85. E85 is race fuel on a budget. Not only are you getting 105 octane out of the box, you're getting the added benefit of ethanol cooling the intake charge. If you live in an area with easy availability to E85 and you're comfortable with tuning, you might want to move this modification up a little in your list. E85 suppresses knock and allows for much smaller pulleys and more advanced timing. When it comes to bang-for-the-buck, I'm not sure you can do any better. You will NEED a fuel pump rewire kit, bigger injectors, and a tune. Some people will tell you that you can get away with just dropping in 42.5 lbs injectors and throwing in a tank of E85 on the stock tune. That's partially right.. E85 requires 30% more fuel, and those injectors are approximately 30% bigger. Unfortunately, that does not account for other tuning that is required to prevent hard cold starts and other drivability issues. 42.5s will likely be too small of an injector if you plan on seriously modding (sub 3.2" pullies, cam, etc). If you're moving to E85 for performance, start with the 60 lbs Siemens/Deka injectors. Keep in mind that your gas mileage WILL suffer. If you can't get E85 easily, your next best bet is an.. Intercooler. The next bang-for-the-buck advanced mod would be an intercooler. Let's face it, the M90s just aren't efficient superchargers when you start spinning them faster than they were originally designed for. The incredibly hot intake charge promotes knock and kills power. If you're serious about performance, and you can't get E85, you need an intercooler. Intercoolers are pricey, but give you the ultimate flexibility with pulleys, tunes, and fuel options. You don't need to worry about straying too far from an E85 station when you're running an IC. You can buy intercooler kits or piece your own together. Ed makes some great phenolic core ICs, which are available here. If you're going to piece a kit together, start with his core. Edit: GrandPrixForums is down for now. Ed's store eBay store is available here. Rockers. High-ratio rockers can be an easier alternative to a mild cam. You won't get as big of gains out of them (since you're only altering the cam lift, not duration, overlap, etc.). Stock rockers are 1.6:1 ratio. The higher the ratio, the more valve lift the rockers add. The ratio of the rockers determines that lift. For example, with a set of 1.9 ratio rockers, the rocker will move 1.9 times the lift of the cam. Adding higher ratio rockers not only increases power out of the box, you're also generally able to run smaller SC pullies and add timing as the engine becomes more efficient at moving air in and out. Deciding on rockers really depends on your future modding considerations. If you plan on a cam, don't bother with rockers; unless you're running a VERY small ratio (like 1.65:1 or 1.7:1), you're not going to be able to pair different ratio rockers and a cam. You will need to upgrade your valve springs when running higher ratio rockers (and let's be honest, your engine probably has well over 100k miles. It's time to do it anyway). It's recommended that you use GM L76/L92 valve springs (GM PN#12589774) and retainers (GM PN#10166344). While you have the springs out, go ahead and change the valve stem seals. You can reuse your stock keepers/locks. Camshaft upgrades are well beyond the scope of this guide. Fortunately, these cars are so well documented it's usually pretty easy to find what you need by searching Google. Keep in mind that mild cams such as the VS and S1X need much less work to get running than more wild cams like the XPZ or S3. Conclusion: Hopefully I've helped to remove a lot of the mystery around modding these cars. The 3800 platform is simple, reliable, and cheap. It's a great way for novice tuners and builders to cut their teeth before moving onto bigger and better things. If you can think of any additional information you would like here, or if I missed something, or if you think I'm a moron, feel free to comment below. I'd like to hear your feedback! runt, White93z34, GOT2B GM and 2 others 5 Quote
l67ss Posted April 19, 2017 Report Posted April 19, 2017 Something to be said about zzp headers is I've seen people have bad o2 fitment issues with them Quote
digitaloutsider Posted April 19, 2017 Author Report Posted April 19, 2017 I can't find anything that suggests EFI Live supports the 3800 PCM. Even if it did, I don't think I'd recommend something like it or TunerCat to a total noob, since there's practically zero community support for it. Quote
Imp558 Posted April 19, 2017 Report Posted April 19, 2017 Damnit! Efilive doesn't work with a 3800, you're right. Efilive is incredible, way more than hptuners but more difficult to maneuver the menus. Tunercat is remarkably simple and the best choice for doing the basics but it doesn't have a logging software so it's not as friendly for ve tables and such. HPTuners is also supported with so much online literature I'm forced to agree that in this instance Hptuners is the logical choice. I was really looking forward to tuning with my Efilive V2 but I guess I'll have to pay $100 to use my hpt tool. Quote
GOT2B GM Posted April 20, 2017 Report Posted April 20, 2017 (edited) Great write up Shaun. Perfect timing too for what I'm doing. Any recommendations for spark plug gap on the AL104's? My starting point for the top swap will be SD headers, f-body magnaflow muffler 180 t stat ZZP MPS with 3.6 (on a gen3 blower) AL 104's Cone filter Scanning for KR with a scangauge II Edited April 20, 2017 by GOT2B GM Quote
l67ss Posted April 20, 2017 Report Posted April 20, 2017 I'd use al605s with a 0.050" gap with a 3.6....possibly 606s with your setup Quote
digitaloutsider Posted April 20, 2017 Author Report Posted April 20, 2017 I agree on 605's because of the top swap. 104's are really too cold for a 3.6 on a Gen 3. Quote
Grandprix1 Posted April 20, 2017 Report Posted April 20, 2017 Is it possible to make one of these for the NA 3800? I'd make one but I don't know enough yet to do that Sent from my iPhone using Tapatalk Quote
digitaloutsider Posted April 20, 2017 Author Report Posted April 20, 2017 Nick's linked guide does cover some stuff for the L36. Same maintenance in this guide applies, obviously. Could always fab up an intake like I describe. Exhaust parts work the same (just go with the 2.5" downpipe and plogs). At the end of the the day, IMHO modding the L36 is kind of pointless, since bolting on a top swap is so ridiculously cheap now. There are cams and tunes, but the only L36 part I'd consider spending money on would be the HV3 intake insert. Quote
GOT2B GM Posted April 20, 2017 Report Posted April 20, 2017 Ok al605's @.050 Sent from my SM-G935W8 using Tapatalk Quote
Grandprix1 Posted April 20, 2017 Report Posted April 20, 2017 Nick's linked guide does cover some stuff for the L36. Same maintenance in this guide applies, obviously. Could always fab up an intake like I describe. Exhaust parts work the same (just go with the 2.5" downpipe and plogs). At the end of the the day, IMHO modding the L36 is kind of pointless, since bolting on a top swap is so ridiculously cheap now. There are cams and tunes, but the only L36 part I'd consider spending money on would be the HV3 intake insert. Really? I'm planning on doing that this summer when I do upper and Lower IMG. I'm planning on getting the front power log as a grad present to myself end of may early June. What makes you like the HV3 insert so much? Sent from my iPhone using Tapatalk Quote
digitaloutsider Posted April 20, 2017 Author Report Posted April 20, 2017 Because it's relatively affordable at $149 and actually has measurable performance gains. Sure there are cams and rockers, but it comes back to "WHY bother??" when a top swap will net you more power for cheaper. If you're happy with the performance of your L36 and you want a little more umph, do the HV3. If you want something that offers better power and gives you a path to future upgrades, top swap. Quote
Grandprix1 Posted April 21, 2017 Report Posted April 21, 2017 Because it's relatively affordable at $149 and actually has measurable performance gains. Sure there are cams and rockers, but it comes back to "WHY bother??" when a top swap will net you more power for cheaper. If you're happy with the performance of your L36 and you want a little more umph, do the HV3. If you want something that offers better power and gives you a path to future upgrades, top swap. Ok cool just curious. I'm not top swapping. Trying to keep it mostly stock with a stock appearance except brakes of course. But that's my plan to install one of those HV3s when I do the upper and lower intake manifold gaskets. They look like they need to be done and I was halfway there when I took the upper intake manifold off. Wasn't terribly hard. I need to figure out which quick disconnect tool I need for the fuel rail. Started leaking on me and dumping fuel everywhere when I took the upper intake manifold off. I'm happy with how it performs but if its cheap then why not you know? Quote
l67ss Posted April 21, 2017 Report Posted April 21, 2017 I'd skip the plog and go headers. And a topswap can easily be stock appearing Quote
l67ss Posted April 21, 2017 Report Posted April 21, 2017 Actually you can get complete topswap for what an hv3 costs Quote
digitaloutsider Posted April 21, 2017 Author Report Posted April 21, 2017 Ok cool just curious. I'm not top swapping. Trying to keep it mostly stock with a stock appearance except brakes of course. But that's my plan to install one of those HV3s when I do the upper and lower intake manifold gaskets. They look like they need to be done and I was halfway there when I took the upper intake manifold off. Wasn't terribly hard. I need to figure out which quick disconnect tool I need for the fuel rail. Started leaking on me and dumping fuel everywhere when I took the upper intake manifold off. I'm happy with how it performs but if its cheap then why not you know? In my opinion, a topswap IS stock because.. it's stock. But I digress. Pretty much every parts store sells the fuel line disconnects you need. The two-in-one disconnect tool is a big POS in my opinion, I finally just bought a whole set of the Lisle quick diconnect tools: https://www.amazon.com/Lisle-39400-Angled-Disconnect-Tool/dp/B000W0UZHG/ref=pd_lpo_vtph_263_bs_t_2?_encoding=UTF8&psc=1&refRID=H7FK80DZG5K1E04TE24D I've needed other disconnects in the set over the years, so it's worth the money to me. IMHO, I wouldn't do headers on an L36. They're total overkill. Psych0matt 1 Quote
Grandprix1 Posted April 21, 2017 Report Posted April 21, 2017 In my opinion, a topswap IS stock because.. it's stock. But I digress. Pretty much every parts store sells the fuel line disconnects you need. The two-in-one disconnect tool is a big POS in my opinion, I finally just bought a whole set of the Lisle quick diconnect tools: https://www.amazon.com/Lisle-39400-Angled-Disconnect-Tool/dp/B000W0UZHG/ref=pd_lpo_vtph_263_bs_t_2?_encoding=UTF8&psc=1&refRID=H7FK80DZG5K1E04TE24D I've needed other disconnects in the set over the years, so it's worth the money to me. IMHO, I wouldn't do headers on an L36. They're total overkill. No I'm not doing headers. They are good on an LS but that's about it. See part of me wants to slowly buy parts to do a top swap and then throw GTP badges on it. Hardest thing to get would be the crank pulley. Everything else should be pretty easy to pull out of the junkyard including heads unless you buy the modified fuel rail from ZZP and go that route. No body would know it's a top swapped GT if it's got GTP badges on it unless they look at the VIN and RPOs and if I tell them. If I could do it for less then $500 I would totally consider it. I'd also have to figure out what head gasket id need so I can run the right compression. ZZPs get you need to run a 4" pulley I think because it's designed for the stock heads with a higher compression. If I'm doing a top swap I want to be able to drop pulleys like a normal GTP with corresponding mods Sent from my iPhone using Tapatalk Quote
Imp558 Posted April 21, 2017 Report Posted April 21, 2017 Crank pulley isn't hard to pull, it's just a harmonic balancer puller. You need to buy a cheap puller to remove your L36 pulley anyway. I like to replace the bolts every 3 uses and only use grade 8 or harder bolts. If one ever sheared inside a pulley it would be a total bitch. carkhz316 1 Quote
digitaloutsider Posted April 21, 2017 Author Report Posted April 21, 2017 You can do it for less than $500 and STILL have hundreds of dollars leftover. ZZP is full of shit, just get the heads, LIM, SC, harmonic balancer, fuel rail, and pulleys/brackets from an L67 car. You don't need any special headgasket. You're going to have the higher compression even with the L67 heads, the difference is in the pistons. It takes 5 minutes to pull a harmonic balancer, including pulling the wheel off. Like Tom says, you'll need a puller anyway when your crank position sensor inevitably shits the bed. Buy the harmonic balancer puller and the GM bolt kit (OEM Tools part # 27296) Quote
Imp558 Posted April 21, 2017 Report Posted April 21, 2017 (edited) Bolts also can come from the hardware store especially if you replace them frequently like I do. The big thing is making sure they are a good hardness. when it comes time for the PCM ask here on the Forum first and if somebody can't reprogram yours we will at least be able to tell you what vehicle to remove one from. Edited April 21, 2017 by Imp558 Quote
Grandprix1 Posted April 21, 2017 Report Posted April 21, 2017 You can do it for less than $500 and STILL have hundreds of dollars leftover. ZZP is full of shit, just get the heads, LIM, SC, harmonic balancer, fuel rail, and pulleys/brackets from an L67 car. You don't need any special headgasket. You're going to have the higher compression even with the L67 heads, the difference is in the pistons. It takes 5 minutes to pull a harmonic balancer, including pulling the wheel off. Like Tom says, you'll need a puller anyway when your crank position sensor inevitably shits the bed. Buy the harmonic balancer puller and the GM bolt kit (OEM Tools part # 27296) Hmm interesting. I may have to look at it and seriously consider it... so I'd still be 9.3:1 compression? I thought the compression was based on the head gasket which you could get thinner or thicker depending on how much compression you want. How low of a pulley could I run? Guess I should probably make a thread about looking into this. Sent from my iPhone using Tapatalk Quote
Grandprix1 Posted April 21, 2017 Report Posted April 21, 2017 I think I'm gonna leave it. I'm making about the same whp that a stock GTP is making crank. I also don't like the idea of it being a fake GTP. I'll get a GTP eventually but I think the top swap isn't something I should do Sent from my iPhone using Tapatalk Quote
digitaloutsider Posted April 21, 2017 Author Report Posted April 21, 2017 Hmm interesting. I may have to look at it and seriously consider it... so I'd still be 9.3:1 compression? I thought the compression was based on the head gasket which you could get thinner or thicker depending on how much compression you want. How low of a pulley could I run? Guess I should probably make a thread about looking into this. Sent from my iPhone using Tapatalk Yes, you can, at a very minor level, affect the compression ratio by using very thin or very thick headgaskets. It's not enough to make any difference on a daily driver. When I dropped an L36 shortblock into my '98 GS years ago, I used FelPro PermaTorque Severe Duty headgaskets, which are slightly thicker than standard ones. The pistons are where the magic happens, look at L36 and L67 ones side by side. I'm fairly sure it's 9.4:1, but it's been a while since I've thought about it. I think I'm gonna leave it. I'm making about the same whp that a stock GTP is making crank. I also don't like the idea of it being a fake GTP. I'll get a GTP eventually but I think the top swap isn't something I should do Sent from my iPhone using Tapatalk Who cares about it being a "fake" GTP? You're not trying to reproduce a passable Yenko Camaro here. And yeah, with enough mods you're making stock GTP power, but I'm willing to guarantee eventually you'll get tired of it and you'd be spending the money all over again for a top swap. I know it's your car and yadda yadda, but in my opinion modding an L36 only made sense when the L67 stuff was still expensive 15 years ago. I see people parting out GTPs and GSs on craigslist all day long and would probably take $250 for an entire longblock. Imp558 1 Quote
Grandprix1 Posted April 21, 2017 Report Posted April 21, 2017 Yes, you can, at a very minor level, affect the compression ratio by using very thin or very thick headgaskets. It's not enough to make any difference on a daily driver. When I dropped an L36 shortblock into my '98 GS years ago, I used FelPro PermaTorque Severe Duty headgaskets, which are slightly thicker than standard ones. The pistons are where the magic happens, look at L36 and L67 ones side by side. I'm fairly sure it's 9.4:1, but it's been a while since I've thought about it. Who cares about it being a "fake" GTP? You're not trying to reproduce a passable Yenko Camaro here. And yeah, with enough mods you're making stock GTP power, but I'm willing to guarantee eventually you'll get tired of it and you'd be spending the money all over again for a top swap. I know it's your car and yadda yadda, but in my opinion modding an L36 only made sense when the L67 stuff was still expensive 15 years ago. I see people parting out GTPs and GSs on craigslist all day long and would probably take $250 for an entire longblock. Yeah that's true. And your probably right haha. I'm going into college and it's plenty quick enough to run around town and to and from school. Who knows maybe in the next year I'll either have a GTP or have a thread asking for parts and how to do it haha. Sent from my iPhone using Tapatalk Quote
