3.4 DOHC LQ1 Torque Specifications
First number is Nm, second number is Lb ft, third number is lb inches.
Accelerator Control Cable Bracket Bolt
 10
 89
Accelerator Control Cable Bracket Nut
 10
 89
Camshaft Carrier Cover Bolt
 11
 97
Camshaft Carrier Thrust Plate Bolt
 10
 89
Camshaft Carrier Thrust Plate Cover Bolt
 10
 89
Camshaft Drive Belt Cover Bolt
 10
 89
Camshaft Drive Sprocket Bolt
 130
 96
Camshaft Housing Assembly Bolt
 27
 20
Camshaft Position Sensor Bolt
 50
 37
Connecting Rod Cap Nut
 20 +75°
 15 +75°
Coolant By-Pass Nut
 25
 18
Coolant Inlet Housing Bolt
 25
 18
Coolant Outlet Bolt
 27
 20
Coolant Pump Bolt
 11
 97
Coolant Pump Pulley Bolt
 25
 18
Crankshaft Balancer Mounting Bolt
 107
 79
Crankshaft Main Bearing Cap Bolt
 50+75°
 37+75°
Crankshaft Main Bearing Cap Stud
 50+75°
 37+75°
Crankshaft Oil Deflector Nut
 25
 18
Crankshaft Pulley-to-Crankshaft Balancer Bolt
 60
 44
Crankshaft Position Sensor Bolt-Front of Engine
 8
 71
Crankshaft Position Sensor Bolt-Side of Engine
 8
 71
Crankshaft Position Sensor Harness Retaining Bracket Bolt
 5
 45
Cylinder Head Bolt
 60 +90°
 44 +90°
Drive Belt Tensioner Bolt
 50
 37
EGR Valve Adapter Brace Nut
 25
 18
EGR Valve Adapter Stud
 10
 89
EGR Tube Assembly
 25
 18
EGR Valve Assembly Nut
 25
 18
Electronic Ignition Control Module Assemble Bolt/Stud
 25
 18
Electronic Ignition Control Assembly Nut
 25
 18
Engine Block Coolant Drain Plug
 19
 14
Engine Block Oil Gallery Plug-Center Rear
 16
 12
Engine Block Oil Gallery Plug-Rear
 33
 24
Engine Block Oil Gallery Plug-Side of Block
 19
 14
Engine Coolant Temperature Sensor
 18
 13
Engine Motor Mount Frame Nut-Engine Left Side
 43
 32
Engine Motor Mount Bracket Nut-Engine Left Side
 43
 32
Engine Motor Mount Frame Nut-Engine Right Side
 43
 32
Engine Motor Mount Bracket Nut-Engine Right Side
 47
 35
Engine Motor Mount Bracket -Front of Block Bolt-Engine Left Side
 103
 76
Engine Motor Mount Bracket-Side of Block Bolts-Engine Left Side
 58
 43
Engine Motor Mount Bracket-Front of Block Bolts-Engine Right Side
 102
 75
Engine Motor Mount Bracket-Side of Block Bolt-Engine Right Side
 58
 43
Engine Motor Mount Bracket-Transaxle Bolts-Engine Right Side
 75
 55
Engine Mount Strut Bracket Bolt
 80
 59
Engine Oil Cooler Connector
 40
 30
Engine Oil Level Sensor
 22
 16
Evaporator Emission Canister Purge Solenoid Mounting Bracket Bolt
 10
 89
Exhaust Manifold Crossover Stud
 9
 80
Exhaust Manifold Nut
 13
 116
Exhaust Manifold Stud
 17
 13
Flywheel Bolt
 82
 60
Front Cover Coolant Drain Plug
 25
 18
Front Cover Bolts- Large
 47
 35
Front Cover Bolts - Small
 27
 20
Front Cover-to-Front Engine Lift Hook Bolt
 25
 18
Front Engine Lift Hook-to-Right Camshaft Carrier Bolt
 50
 37
Front Engine Lift Hook-to-Right Cylinder Head Bolt (Access through Front Cover)
 50
 37
Fuel Pipe Clip Bolt
 7
 62
Fuel Pipe Retainer Screw
 3
 27
Fuel Rail Assembly Bolt
 10
 89
Ignition Coil Bolt
 25
 18
Ignition Coil Nut
 25
 18
Intermediate Drive Shaft Retainer Screw
 10
 89
Intermediate Shaft Belt Sprocket Bolt
 130
 96
Knock Sensor
 21
 15
Manifold Absolute Pressure Sensor Bracket Bolt
 8
 71
Lower Intake Manifold Bolt - Center
First Pass
 7
 62
Final Pass
 13
 115
Lower Intake Manifold Bolt - Corner
First Pass
 13
 115
Final Pass
 25
 18
 40
 30
Oil Cooler Hose Fitting
 25
 18
Oil Distribution Cover Bolt
 27
 20
Oil Filter
 16
 12
OIl Filter Fitting
 67
 49
Oil Level Indicator Bolt
 10
 89
Oil Pan Bolt-Except Rear
 11
 97
Oil Pan Bolt-Rear (2)
 27
 20
Oil Pan Drain Plug
 25
 18
Oil Pan Nut
 11
 97
Oil Pan Stud-to-Cylinder Block
 10
 89
Oil Pressure Switch
 32
 24
Oil Pump Cover Bolt
 10
 89
Oil Pump Drive Clamp Bolt
 36
 27
Oil Pump-to-Rear Main Cap Bolt
 54
 40
Power Brake Booster Vacuum Pipe Fitting
 18
 13
Rear Engine Mount Strut Bracket Bolt
 82
 60
Secondary Air Injection Pipe
 25
 18
Secondary Air Injection Pipe Nut-Left Side
 25
 18
Secondary Air Injection Pipe Support Bolt
 10
 89
Secondary Air Injection Pipe Nut-Right Side
 10
 89
Serpentine Drive Belt Tensioner Bolt
 50
 37
Spark Plug
 20
 15
Throttle Body Adapter Bolt
 25
 18
Throttle Body Adapter Nut
 25
 18
Throttle Body Heater Outlet Hose Nipple
 18
 13
Throttle Body Stud
 4
 36
Throttle Body Bolt
 10
 89
Tie Bar Bracket
 26
 19
Timing Belt Cover Bolt
 10
 89
Timing Belt Idler Pulley Bolt
 50
 37
Timing Belt Tensioner Actuator Bracket Bolt
 50
 37
Timing Belt Tensioner Actuator Pulley Pivot Bolt
 50
 37
Timing Belt Tenisoner Actuator Side Plate Bolt
 27
 20
Timing Chain Tensioner Bolt
 27
 20
Engine Mount Strut and Engine Lift Bracket Bolt
 70
 52
Upper Intake Manifold Retaining Bolt
 26
 19
Water Inlet Fitting to Front Cover
 27
 20
Vacuum Source Manifold Mounting Bolt
 7
 62
Thanks for taking the time to post this. This is very handy!
Edited by MemphisMan
  • Like 1
