digitaloutsider Posted April 14, 2017 Report Posted April 14, 2017 Accelerator Control Cable Bracket Bolt/Nut 10 N·m 89 lb in Camshaft Position Sensor Bolt 10 N·m 89 lb in Camshaft Sprocket Bolt 140 N·m 103 lb ft Camshaft Thrust Plate Screw 10 N·m 89 lb in Connecting Rod Bearing Bolt First Pass 25 N·m 18 lb ft Final Pass 100 degrees Coolant Drain Plug 19 N·m 14 lb ft Coolant Temperature Sensor 23 N·m 17 lb ft Crankshaft Balancer Bolt 103 N·m 76 lb ft Crankshaft Main Bearing Cap Bolt/Stud First Pass 50 N·m 37 lb ft Final Pass 77 degrees Crankshaft Oil Deflector Nut 25 N·m 18 lb ft Crankshaft Position Sensor Bolt - Front Cover 10 N·m 89 lb in Crankshaft Position Sensor Bolt - Side of Engine Block 11 N·m 98 lb in Crankshaft Position Sensor Wiring Bracket Bolt 50 N·m 37 lb ft Crankshaft Position Sensor Shield Bolt 11 N·m 98 lb in Cylinder Head Bolt First Pass 60 N·m 44 lb ft Final Pass 95 degrees Drive Belt Idler Pulley Bolt 50 N·m 37 lb ft Drive Belt Shield Bolt 10 N·m 89 lb in Drive Belt Tensioner Bolt 50 N·m 37 lb ft EGR Valve to EGR Valve Pipe Bolt 30 N·m 22 lb ft EGR Valve Adapter Pipe to Exhaust Manifold Nut 25 N·m 18 lb ft Engine Flywheel Bolt 71 N·m 52 lb ft Engine Front Cover Bolt - Large 55 N·m 41 lb ft Engine Front Cover Bolt - Medium 55 N·m 41 lb ft Engine Front Cover Bolt - Small 27 N·m 20 lb ft Engine Mount Bracket Bolt 58 N·m 43 lb ft Engine Mount Lower Nut 43 N·m 32 lb ft Engine Mount Strut and Lift Bracket Bolt - Engine Left Rear 70 N·m 52 lb ft Engine Mount Strut Bolt/Nut 48 N·m 35 lb ft Engine Mount Strut Bracket Bolt - Upper Radiator Support 28 N·m 21 lb ft Engine Mount Strut Bracket Bolt - Vehicle Right Side 50 N·m 37 lb ft Engine Mount Upper Nut 47 N·m 35 lb ft Engine Oil Pressure Indicator Switch 16 N·m 12 lb ft Engine Wiring Harness Bracket Bolt 13 N·m 115 lb in Exhaust Crossover Pipe Heat Shield Bolt 10 N·m 89 lb in Exhaust Crossover Pipe Nut/Stud 25 N·m 18 lb ft Exhaust Manifold Heat Shield Bolt 10 N·m 89 lb in Exhaust Manifold Nut 16 N·m 12 lb ft Exhaust Manifold Stud 18 N·m 13 lb ft Fuel Feed Pipe to Fuel Injector Rail Nut 17 N·m 13 lb ft Fuel Injector Rail Bolt 10 N·m 89 lb in Fuel Pipe Bracket Bolt/Stud 50 N·m 37 lb ft Fuel Pipe Clip Bolt 8 N·m 71 lb in Fuel Return Pipe to Fuel Injector Rail Nut 17 N·m 13 lb ft Generator Bracket and Front Engine Lift Hook Bolt 50 N·m 37 lb ft Heated Oxygen Sensor 42 N·m 31 lb ft Heater Inlet Pipe Nut 25 N·m 18 lb ft Ignition Coil Bracket Bolt/Nut/Stud 25 N·m 18 lb ft Intake Manifold Coolant Pipe Bolt 10 N·m 89 lb in Knock Sensor 19 N·m 14 lb ft Lower Intake Manifold Bolt First Pass 7 N·m 62 lb in Final Pass - 4 Middle Bolts 13 N·m 115 lb in Final Pass - 4 Outside Bolts 25 N·m 18 lb ft MAP Sensor Bolt 5 N·m 44 lb in MAP Sensor Bracket Bolt 25 N·m 18 lb ft Oil Cooler Pipe Bracket Bolt 10 N·m 89 lb in Oil Filter 13 N·m 115 lb in Oil Filter Bypass Hole Plug 19 N·m 14 lb ft Oil Filter Fitting 39 N·m 29 lb ft Oil Gallery Plug - 1/4 inch 19 N·m 14 lb ft Oil Gallery Plug - 3/8 inch 33 N·m 24 lb ft Oil Level Indicator Tube Stud 25 N·m 18 lb ft Oil Level Sensor Bolt 10 N·m 89 lb in Oil Pan Bolt 25 N·m 18 lb ft Oil Pan Drain Plug 25 N·m 18 lb ft Oil Pan Side Bolt 50 N·m 37 lb ft Oil Pump Drive Clamp Bolt 36 N·m 27 lb ft Oil Pump Mounting Bolt 41 N·m 30 lb ft Spark Plug 27 N·m 20 lb ft Thermostat Bypass Pipe to Cylinder Head Nut 25 N·m 18 lb ft Thermostat Bypass Pipe to Engine Front Cover Bolt 12 N·m 106 lb in Thermostat Bypass Pipe to Throttle Body Nut 25 N·m 18 lb ft Throttle Body Bolt/Stud 25 N·m 18 lb ft Timing Chain Dampener Bolt 21 N·m 15 lb ft Upper Intake Manifold Bolt/Stud 25 N·m 18 lb ft Valve Lifter Guide Bolt 10 N·m 89 lb in Valve Rocker Arm Bolt First Pass 19 N·m 14 lb ft Final Pass 30 degrees Valve Rocker Arm Cover Bolt 10 N·m 89 lb in Water Outlet Bolt 25 N·m 18 lb ft Water Pump Bolt 10 N·m 89 lb in Water Pump Pulley Bolt 25 N·m 18 lb ft Quote
