3100 L82 Torque Specifications
Accelerator Control Cable Bracket Bolt/Nut
 10 N·m
 89 lb in
Camshaft Position Sensor Bolt
 10 N·m
 89 lb in
Camshaft Sprocket Bolt
 140 N·m
 103 lb ft
Camshaft Thrust Plate Screw
 10 N·m
 89 lb in
Connecting Rod Bearing Cap Nut
 20 N·m + 75°
 15 lb ft + 75°
Coolant Drain Plug
 19 N·m
 14 lb ft
Coolant Temperature Sensor
 23 N·m
 17 lb ft
Crankshaft Balancer Bolt
 103 N·m
 76 lb ft
Crankshaft Main Bearing Cap Bolt/Stud
 50 N·m +77°
 37 lb ft + 77°
Crankshaft Oil Deflector Nut
 25 N·m
 18 lb ft
Crankshaft Position Sensor Bolt -- Front Cover
 10 N·m
 89 lb in
Crankshaft Position Sensor Stud -- Side of Engine Block
 11 N·m
 98 lb in
Crankshaft Position Sensor Wiring Bracket Bolt
 27 N·m
 20 lb ft
Cylinder Head Bolt
 60 N·m + 95°
 44 lb ft + 95°
Drive Belt Shield Bolt
 10 N·m
 89 lb in
Drive Belt Tensioner Bolt
 50 N·m
 37 lb ft
EGR Valve to EGR Valve Pipe Bolt
 25 N·m
 18 lb ft
EGR Valve Adapter Pipe to Exhaust Manifold Nut
 25 N·m
 18 lb ft
Engine Flywheel Bolt
 71 N·m
 52 lb ft
Engine Front Cover Bolt -- Large
 55 N·m
 41 lb ft
Engine Front Cover Bolt -- Medium
 47 N·m
 35 lb ft
Engine Front Cover Bolt -- Small
 21 N·m
 15 lb ft
Engine Mount Bracket Bolt
 58 N·m
 43 lb ft
Engine Mount Lower Nut
 43 N·m
 32 lb ft
Engine Mount Strut and Lift Bracket Bolt -- Engine Left Rear
 70 N·m
 52 lb ft
Engine Mount Strut Bolt/Nut
 48 N·m
 35 lb ft
Engine Mount Strut Bracket Bolt -- Upper Radiator Support
 28 N·m
 21 lb ft
Engine Mount Strut Bracket Bolt -- Vehicle Right Side
 50 N·m
 37 lb ft
Engine Mount Upper Nut
 47 N·m
 35 lb ft
Engine Oil Pressure Indicator Switch
 13 N·m
 115 lb in
Engine Wiring Harness Bracket Bolt
 13 N·m
 115 lb in
Exhaust Crossover Pipe Heat Shield Bolt
 10 N·m
 89 lb in
Exhaust Crossover Pipe Nut/Stud
 25 N·m
 18 lb ft
Exhaust Manifold Heat Shield Bolt
 10 N·m
 89 lb in
 16 N·m
 12 lb ft
Exhaust Manifold Stud
 18 N·m
 13 lb ft
Fuel Feed Pipe to Fuel Injector Rail Nut
 17 N·m
 13 lb ft
Fuel Injector Rail Bolt
 10 N·m
 89 lb in
Fuel Pipe Bracket Bolt/Stud
 50 N·m
 37 lb ft
Fuel Pipe Clip Bolt
 8 N·m
 71 lb in
Fuel Return Pipe to Fuel Injector Rail Nut
 17 N·m
 13 lb ft
Generator Bracket and Front Engine Lift Hook Bolt
 50 N·m
 37 lb ft
Heated Oxygen Sensor
 42 N·m
 31 lb ft
Heater Inlet Pipe Nut
 25 N·m
 18 lb ft
Ignition Coil Bracket Bolt/Nut/Stud
 25 N·m
 18 lb ft
Intake Manifold Coolant Pipe Bolt
 10 N·m
 89 lb in
Knock Sensor
 19 N·m
 14 lb ft
Lower Intake Manifold Bolt
 13 N·m
 115 lb in
MAP Sensor Bolt
 5 N·m
 44 lb in
Oil Cooler Connector
 50 N·m
 37 lb ft
Oil Cooler Hose Fitting
 19 N·m
 14 lb ft
Oil Cooler Pipe Bracket Bolt
 10 N·m
 89 lb in
Oil Filter
 13 N·m
 115 lb in
Oil Filter Bypass Hole Plug
 19 N·m
 14 lb ft
Oil Filter Fitting
 39 N·m
 29 lb ft
Oil Gallery Plug -- 1/4 inch
 19 N·m
 14 lb ft
Oil Gallery Plug -- 3/8 inch
 33 N·m
 24 lb ft
Oil Level Indicator Tube Stud
 25 N·m
 18 lb ft
Oil Level Sensor Bolt
 10 N·m
 89 lb in
Oil Pan Bolt
 25 N·m
 18 lb ft
Oil Pan Drain Plug
 25 N·m
 18 lb ft
Oil Pan Side Bolt
 50 N·m
 37 lb ft
Oil Pump Cover Bolt
 10 N·m
 89 lb in
Oil Pump Drive Clamp Bolt
 36 N·m
 27 lb ft
Oil Pump Mounting Bolt
 41 N·m
 30 lb ft
Spark Plug
Spark Plug - Initial Installation
 20 N·m
 15 lb ft
Spark Plug - Reinstallation
 15 N·m
 11 lb ft
Thermostat Bypass Pipe to Cylinder Head Nut
 25 N·m
 18 lb ft
Thermostat Bypass Pipe to Engine Front Cover Bolt
 12 N·m
 106 lb in
Thermostat Bypass Pipe to Throttle Body Nut
 25 N·m
 18 lb ft
Throttle Body Bolt/Stud
 25 N·m
 18 lb ft
Timing Chain Dampener Bolt
 21 N·m
 15 lb ft
Upper Intake Manifold Bolt/Stud
 25 N·m
 18 lb ft
Valve Lifter Guide Bolt
 10 N·m
 89 lb in
Valve Rocker Arm Bolt
 19 N·m + 30°
 14 lb  ft+ 30°
Valve Rocker Arm Cover Bolt
 10 N·m
 89 lb in
Water Outlet Bolt
 25 N·m
 18 lb ft
Water Pump Bolt
 10 N·m
 89 lb in
Water Pump Pulley Bolt
 25 N·m
 18 lb ft
