Accelerator Control Cable Bracket Bolt
 16 N·m
 12 lb ft
Balance Shaft Driven Gear Bolt
 22 + 70° N·m
 16 + 70° lb ft
Balance Shaft Retainer Bolt
 30 N·m
 22 lb ft
Camshaft Position Sensor Bolt
 10 N·m
 89 lb in
Camshaft Sprocket Bolt
 100 + 90° N·m
 74 + 90° lb ft
Camshaft Thrust Plate Bolt
 15 N·m
 11 lb ft
Canister Purge Solenoid Valve Bracket Bolt (VIN K)
 50 N·m
 37 lb ft
Canister Purge Vacuum Switch Bolt (VIN  K)
 50 N·m
 37 lb ft
Connecting Rod Cap Bolt
 27 + 50° N·m
 20 + 50° lb ft
Crankshaft Balancer Bolt
 150 + 76° N·m
 111 + 76° lb ft
Crankshaft Main Bearing Cap Bolt
 40 + 110° N·m
 30 + 110° lb ft
Crankshaft Main Bearing Cap Bolt (Side)
 15 + 45° N·m
 11 + 45° lb ft
Crankshaft Position Sensor Stud
 30 N·m
 22 lb ft
Crankshaft Rear Oil Seal Housing Bolt
 15 + 50° N·m
 11 + 50° lb ft
Cylinder Head Bolt
 50 + 120° N·m
 37 + 120° lb ft
Drive Belt Tensioner Bracket Bolt/Nut
 50 N·m
 37 lb ft
Drive Belt Tensioner Bracket Stud
 6 N·m
 53 lb in
EGR Valve Adapter Bolt
 50 N·m
 37 lb ft
EGR Valve Inlet Pipe Bolt
 29 N·m
 21 lb ft
EGR Valve Nut
 29 N·m
 21 lb ft
EGR Valve Outlet Pipe Bolt/Nut
 29 N·m
 21 lb ft
Engine Block Coolant Drain Plug (VIN 1)
 18 N·m
 13 lb ft
Engine Block Coolant Drain Plug (VIN K)
 30 N·m
 22 lb ft
Engine Block Oil Gallery Plug
 30 N·m
 22 lb ft
Engine Coolant Temperature Sensor
 25 N·m
 18 lb ft
Engine Flywheel Bolt
 15 + 50° N·m
 11 + 50° lb ft
Engine Front Cover Bolt/Stud
 20 + 40° N·m
 15 + 40° lb ft
Engine Lift Bracket Bolt/Nut/Stud
 30 N·m
 22 lb ft
Engine Mount Nut, Lower
 78 N·m
 58 lb ft
Engine Mount Nut, Upper
 78 N·m
 58 lb ft
Engine Oil Pressure Indicator Switch
 16 N·m
 12 lb ft
Exhaust Crossover Heat Shield Nut
 20 N·m
 15 lb ft
Exhaust Crossover Pipe Bolt/Stud
 18 N·m
 13 lb ft
Exhaust Manifold Bolt/Nut
 30 N·m
 22 lb ft
Exhaust Manifold Heat Shield Nut
 20 N·m
 15 lb ft
Exhaust Manifold Stud (Inner)
 30 N·m
 22 lb ft
Exhaust Manifold Stud (Outer)
 10 N·m
 89 lb in
Fuel Injector Rail Nut
 10 N·m
 89 lb in
Fuel Injector Rail Stud
 25 N·m
 18 lb ft
Fuel Injector Sight Shield Bracket Nut
 30 N·m
 22 lb ft
Generator Brace Bracket Bolt
 50 N·m
 37 lb ft
Heated Oxygen Sensor
 42 N·m
 31 lb ft
ICM Bolt (VIN 1)
 30 N·m
 22 lb ft
ICM Nut
 50 N·m
 37 lb ft
ICM Stud (VIN K)
 6 N·m
 53 lb in
ICM Wiring Harness Bolt
 2 N·m
 18 lb in
Idler Pulley Bolt
 50 N·m
 37 lb ft
Idler Pulley Bracket Bolt
 30 N·m
 22 lb ft
Lower Intake Manifold Bolt
 15 N·m
 11 lb ft
MAP Sensor Bolt (VIN 1)
 3 N·m
 27 lb in
MAP Sensor Bracket Bolt (VIN 1)
 30 N·m
 22 lb ft
Oil Cooler Adapter Connector
 50 N·m
 37 lb ft
Oil Filter
 30 N·m
 22 lb ft
Oil Filter Adapter Bolt
 15 + 50° N·m
 11 + 50° lb ft
Oil Level Indicator Switch
 20 N·m
 15 lb ft
Oil Level Indicator Tube Nut
 19 N·m
 14 lb ft
Oil Pan Bolt
 14 N·m
 125 lb in
Oil Pan Drain Plug
 30 N·m
 22 lb ft
Oil Pump Cover Screw
 11 N·m
 98 lb in
Oil Pump Screen Bolt
 15 N·m
 11 lb ft
Power Brake Booster Heat Shield Nut
 20 N·m
 15 lb ft
Spark Plug
 27 N·m
 20 lb ft
Starter Motor Heat Shield Bolt
 30 N·m
 22 lb ft
Supercharger Bolt/Stud (VIN 1)
 23 N·m
 17 lb ft
Supercharger Bypass Valve and Fuel Pressure Regulator Valve Harness Bolt (VIN 1)
 10 N·m
 89 lb in
Supercharger Bypass Valve Nut (VIN 1)
 8 N·m
 71 lb in
Throttle Body Nut
 10 N·m
 89 lb in
Throttle Body Support Bolt (VIN K)
 10 N·m
 89 lb in
Timing Chain Dampener Bolt
 22 N·m
 16 lb ft
Upper Intake Manifold Bolt (VIN K)
 10 N·m
 89 lb in
Valve Lifter Guide Retainer Bolt
 30 N·m
 22 lb ft
Valve Rocker Arm Bolt
 15 + 90° N·m
 11 + 90° lb ft
Valve Rocker Arm Cover Bolt
 10 N·m
 89 lb in
Water Outlet Bolt
 27 N·m
 20 lb ft
Water Pump Bolt
 15 + 80° N·m
 11 + 80° lb ft
Water Pump Pulley Bolt
 13 N·m
 116 lb in
Wiring Harness Shield Bolt/Nut
 10 N·m
 89 lb in
