W30olds Posted March 22, 2017 Report Posted March 22, 2017 Has anyone ever replace the rear control arms? Not the trailing arms. Looks fairly straight forward. A few months back I had the monoleaf and struts replaced. When I went to have it aligned the tech showed me the bend control arm. Not sure if it was bent before the spring was replaced, or not. Anyway ordered a new part from GM today. I've gotten a new job since my car was fixed and haven't driven the GP that much the last 2 months, but wanted to get it fixed properly. Anyone tackeled this before? Thanks, Andy Quote
jman093 Posted March 23, 2017 Report Posted March 23, 2017 The lateral links? Yes, dozens of us have replaced them. The two rearward ones can be changed in a couple of minutes. The two front ones are a different story. GM stupidly installed the inner bolt on each from the front and they hit the fuel tank before coming out. Either the fuel tank or the subframe will need partially dropped to get it out. When going back together, make sure to stick that bolt in from the rear so they will forever be easily replaceable if need be. Also, if replacing lateral links, get 2nd/3rd gen ones. They are tubular and don't bend like spaghetti noodles like the 1st gen ones do (as you've now found out). Setting rear toe on alignment is also MUCH easier and more accurate as the 2nd/3rd gen rear links are adjustable. Dat50go and W30olds 2 Quote
W30olds Posted March 23, 2017 Author Report Posted March 23, 2017 Thanks for the info sir. Looks like a fun task. I'm going to ask about the tubular style. I just ordered the one from the VIN off the car. I'm assuming it's probably just like the original. Still no idea how it was bent. My guess when the shop installed the monoleaf it was tweaked and nobody said anything to me. I dunt know that for sure though. Just a guess Quote
Imp558 Posted March 23, 2017 Report Posted March 23, 2017 And when you jack up the mono Leaf to relieve the pressure on the spindle assemblies you have to use a block between the Jack and the fiberglass. Otherwise you run the risk of getting a scratch in the fiberglass that could turn into a fracture. W30olds 1 Quote
vipmiller803 Posted March 23, 2017 Report Posted March 23, 2017 (edited) The lateral links? Yes, dozens of us have replaced them. The two rearward ones can be changed in a couple of minutes. The two front ones are a different story. GM stupidly installed the inner bolt on each from the front and they hit the fuel tank before coming out. Either the fuel tank or the subframe will need partially dropped to get it out. When going back together, make sure to stick that bolt in from the rear so they will forever be easily replaceable if need be. Also, if replacing lateral links, get 2nd/3rd gen ones. They are tubular and don't bend like spaghetti noodles like the 1st gen ones do (as you've now found out). Setting rear toe on alignment is also MUCH easier and more accurate as the 2nd/3rd gen rear links are adjustable. How irreplaceable are these upper/inner bolts? I haven't done this so I do not speak from experience, but from what you're saying, they were just assembled going the unnecessary "wrong" way. Is it a viable option to cut them off and replace with new ones going the more easily accessible way? Edited March 23, 2017 by vipmiller803 Dat50go 1 Quote
Imp558 Posted March 23, 2017 Report Posted March 23, 2017 That's an interesting idea, barring the whole "Sparks by the gas tank" thing. It would probably be more efficient to lower the subframe than use a hacksaw. Quote
W30olds Posted March 30, 2017 Author Report Posted March 30, 2017 So still waiting on the part to arrive. Ordered it from GMpartsdirect.com because they are the best on prices, but slow to ship. Question......the GM guy said both rear end front/rear links are the same part number. So if your sitting in the drivers seat and the lateral link is the one on the drivers rear towards the front of the car is that the front, or rear lat. link? (Basically in the front of the monoleaf spring) GM guy just said they're both the same, but couldn't tell me if it's front, or rear. Quote
Imp558 Posted March 30, 2017 Report Posted March 30, 2017 The ones in front of the spring are front Quote
W30olds Posted March 30, 2017 Author Report Posted March 30, 2017 The ones in front of the spring are front Makes perfect since to me too. Not sure why the GM guy was so challenged Quote
White93z34 Posted March 31, 2017 Report Posted March 31, 2017 I looked into replacing my lateral links with OEM parts from the dealer but the best price I could get was about $90 each. Ended up modifying 2g ones and was all in for about $100 Trailing arms are cheap and easy to obtain though. Quote
W30olds Posted April 13, 2017 Author Report Posted April 13, 2017 Finally got the replacement link for my car. Took forever for it to come, but hope to get it changed out over the weekend. Then I'm going to take it and have the rear alignment checked and corrected if needed. Thanks for the info guys! Quote
MAFerris85 Posted July 9, 2017 Report Posted July 9, 2017 Does anyone know if the BMR suspension kit for 96-06 will fit a first gen, I have a 93 Z34. The stock part numbers match but wanted to know if this kit fits Quote
jman093 Posted July 10, 2017 Report Posted July 10, 2017 The control arms will work, but $530 is insane to spend for that. Imp558 1 Quote
MAFerris85 Posted July 10, 2017 Report Posted July 10, 2017 Is there one that is a better quality and/or price, also what about the strut braces and lateral links Quote
Imp558 Posted July 10, 2017 Report Posted July 10, 2017 Is there one that is a better quality and/or price, also what about the strut braces and lateral links GOT2BGM Quote
jman093 Posted July 10, 2017 Report Posted July 10, 2017 Is there one that is a better quality and/or price, also what about the strut braces and lateral links All the control arms will work, the laterals included, but the general upgrade for trailing arms is the 2G/3G GMPP/9C1 arms, the 3G V8 arms, or the Dorman ones. For the laterals, the 2G/3G stuff is the upgrade. If wanting the fronts to be adjustable like the rears, buy four rear arms you can have them shortened/rewelded to fit in the front. GOT2BGM on the forum will do them if you can't do it locally. For all that you'd be looking at $175 or something. It wouldn't have poly bushings, but I'm not sure that would be much of an upgrade and people report the ride quality suffers. The strut braces won't work. Quote
MAFerris85 Posted July 12, 2017 Report Posted July 12, 2017 Anyone know if the HT Motorsports pieces are good Quote
Imp558 Posted July 12, 2017 Report Posted July 12, 2017 Dorman tubular trailing arms are actually really nice, GOT2BGM on our forum mods the second gen adjustable lats so you can have 4 adjustable lateral links in the back and put your wheels anywhere you want them within that adjustment. He puts poly bushings in them too. I personally can't see any benefit in buying the big-name ones when we have an option like that. That's the setup my third revision of my Regal is getting. Quote
95GS Posted July 12, 2017 Report Posted July 12, 2017 I appreciate that GOT2BGM was quick to respond to my questions about these links, with photo. Imp558 1 Quote
Imp558 Posted July 12, 2017 Report Posted July 12, 2017 His work is nice and he's a good friend. I have the prototype 3800 billet dogbones for my car. Had to tap a couple holes in the core support and use early brackets. Those are beautiful. Also have his rear stb brackets. Quote
MAFerris85 Posted August 1, 2017 Report Posted August 1, 2017 Who was it on here that made them fully adjustable with heim joints, I think he also made coilover setups Quote
Imp558 Posted August 1, 2017 Report Posted August 1, 2017 Maybe a long time ago if it happened. Matt modified my lats, and they look great. http://www.w-body.com/user/1248-got2b-gm/ Quote
W30olds Posted November 5, 2017 Author Report Posted November 5, 2017 Finally had the link replaced yesterday at the local garage. I decided to let them do the job because we'll I didn't have all the time or tools. Long story short it got replaced. The tech put the car on the alignment rack and got all 4 wheels within spec. I'm super excited its all fixed correctly and that he was able to get the rear end lined up right. Apparently the rear toe and camber are adjustable even though I've had many shops say otherwise. I've even had a GM dealer tell me there was not adjustments in the rear. BS! After watching and learning from the alignment guy we both learned how to adjust the toe. GM has a special tool for the rear toe stuff. It's basically a hook that has threaded rods on the end. It hooks into the center cradle and the other in the holes on the latreal links. Adjust as needed on the threaded rod, or large pry bar. If anyone tells you the rear end is not adjustable find another repair shop, or inform them it is. Quote
jman093 Posted November 6, 2017 Report Posted November 6, 2017 Rear camber is not adjustable other than finding slop in the shock/knuckle bolts. If your shop told you they adjusted it otherwise, they're lying. Quote
