jaredbonner1 Posted March 21, 2017 Report Posted March 21, 2017 Has anyone tried to make their own fan control switch? I made one on my Saturn by tapping into the relay and connecting it to ground on a switch, but the grand prix has 3 different fan relays and I could only get one fan to work at a time. ZZP has one for sale but I really don't think it's worth what they are asking... Quote
jaredbonner1 Posted March 21, 2017 Author Report Posted March 21, 2017 I should also mention my major at my college is industrial electricity so I can definitely make it work one way or another Quote
White93z34 Posted March 21, 2017 Report Posted March 21, 2017 I'm guessing you have a 97-03 Grand Prix. The computer already does everything you want to do, just set the turn on temps and enjoy Quote
Grandprix1 Posted March 21, 2017 Report Posted March 21, 2017 Theoretically it should just be a basic switch. Maybe try a thicker gauge wire and separate that wire into each of the 3 relays. I'm assuming that switch is commanding it via OBD but I'm probably wrong on that one. It looks like only one wire that ZZP has on that switch. Maybe see if you can find the directions for how to install that and see where it connects Sent from my iPhone using Tapatalk Quote
digitaloutsider Posted March 21, 2017 Report Posted March 21, 2017 Do you really need to be able to manually control the fans? I would get the fan temps set in the tune and not dick with manual switches and overrides. Quote
jaredbonner1 Posted March 21, 2017 Author Report Posted March 21, 2017 Well I live down in Mississippi and my car gets too hot with the supercharger for my liking. I already put a 180 t-stat but if I'm sitting in traffic it can get up to 215 and 220. I could get it with my tuned PCM but I have a lot of stuff to spend money on before I can get around to a PCM. Quote
jaredbonner1 Posted March 21, 2017 Author Report Posted March 21, 2017 I'm guessing you have a 97-03 Grand Prix. The computer already does everything you want to do, just set the turn on temps and enjoy It is an 01. All I have is an old adapter and torque pro. What do I need to start setting things like that? Do you need a hp tuner and a computer or is it easier than that? Quote
Imp558 Posted March 21, 2017 Report Posted March 21, 2017 Buy your own interface and you'll have the ability to set fan temps and much more.. I have my primary temp at 190 to coordinate with a 180 stat and secondary at 205 to coordinate with a 195 stat. A switch under the hood select which input to the PCM is being used to throw both relays at once. I call it my summer / winter switch and change the thermostat twice a year. Summer I run about 187 with a stock radiator. I don't have A/C or it would get complicated as the secondary fan control is also run via A/C pressure to cool the condenser. Quote
vipmiller803 Posted March 21, 2017 Report Posted March 21, 2017 (edited) I do agree that the cleanest way is to do it via tune. Has anyone tried to make their own fan control switch? To answer your question directly, though, I have done this before many times. Your fans have three relays because they run in series on low and parallel on high. Ground relay 1 for low speed and all three for high speed. Although this schematic is not specific to your vehicle, most of that era gm fans that have low and high speeds work in the same way. Again, the wire colors and such are not grand prix specific. One last note: I would use something to isolate the ecu from your grounds (use either multipole switch or additional relays). Although you may not hurt your ecu by grounding what is ungrounded in this specific case, it may set a code. Edited March 21, 2017 by vipmiller803 Quote
Imp558 Posted March 21, 2017 Report Posted March 21, 2017 Yes, diode isolating the pcm low controls is always a good idea if you're tapping that circuit for an override. Quote
Nas Escobar Posted March 22, 2017 Report Posted March 22, 2017 I'll have to do this on my Z34 if my fans work because they don't come on... Not even when I jump the ALDL to pull codes (fan usually would come on). Anyways, wiring is cheap at Walmart and I'm pretty sure they sell switches there. You could probably do what zzp sells for $20 Quote
Vivikos2 Posted May 29, 2017 Report Posted May 29, 2017 I agree with you. Stick RPG 2 unblocked Quote
