MemphisMan Posted February 3, 2018 Author Report Posted February 3, 2018 I'd be interested. I'll throw out a price, $20 a pair seem fair? GabsOlds and jmjp5055 2 Quote
GabsOlds Posted February 4, 2018 Report Posted February 4, 2018 I'd be interested. I'll throw out a price, $20 a pair seem fair? i definitely would order 2 pairs if they are aluminum. jmjp5055 1 Quote
cdn_olds_94 Posted February 16, 2018 Report Posted February 16, 2018 i definitely would order 2 pairs if they are aluminum. I agree. Aluminum would be the way to go, as the original parts on the car were plastic and were not known to last. I found a pair of NOS cups and lent one to a friend of my son who's a very good machinist and he was going to make a master set in aluminum. But he lost the one I lent him and I will not give him the second one in case he looses that one as well. I would order 2 sets if they were aluminum as well. jmjp5055 1 Quote
94 olds vert Posted February 16, 2018 Report Posted February 16, 2018 (edited) I have the aluminum pin cups. I wonder if I could have someone make them. If there is enough interest, I would sell them here. Edited February 16, 2018 by 94 olds vert jmjp5055 1 Quote
Imp558 Posted February 16, 2018 Report Posted February 16, 2018 Years ago I toyed with liquid plastic molding. Essentially you take a something or another and submerge it in a very strechy liquid rubber. After the rubber dries you pop it out and pour plastic in. The plastic and rubber come in different grades of durability, most of which are far superior to what we had in the early 90s. This stuff is not expensive either. https://www.smooth-on.com/ jmjp5055 1 Quote
oldmangrimes Posted February 16, 2018 Report Posted February 16, 2018 I'll buy a set. Aluminum, plastic, steel, wood, rubber, scrimshaw, I don't care as long as they fit, mine isn't a show car. Currently I just have the original broken plastic pieces wrapped in duct tape and jammed back in the hole in the header. I could engineer a better solution, but I've got so many other projects going on I'd rather just let someone else figure it out and pay them. I would prefer an easy replacement, something I could just drop in with some adhesive without having to disassemble the header. jmjp5055 and rich_e777 2 Quote
cdn_olds_94 Posted February 17, 2018 Report Posted February 17, 2018 I have the aluminum pin cups. I wonder if I could have someone make them. If there is enough interest, I would sell them here. I'm very interested. See what you can do and let us know if it's doable. I'm in for a set or two. jmjp5055 1 Quote
kzwslf Posted May 19, 2018 Report Posted May 19, 2018 If you are interested in plastic guides, P/N 12513780, email me at Cutlass12513780@gmail.com for photos and info. Quote
rich_e777 Posted May 20, 2018 Report Posted May 20, 2018 Yeah post some info about what you`re offering here first before PMs. oldmangrimes and Nas Escobar 2 Quote
kzwslf Posted August 7, 2018 Report Posted August 7, 2018 Following are photos of guides I have made on a 3D printer. I do not believe there is an NOS part on the planet. 94 olds vert 1 Quote
GabsOlds Posted August 8, 2018 Report Posted August 8, 2018 How much are you selling the printed parts for? Anyone working on aluminum cups? Those would be a better solution; permanent. I would like 2 sets of the aluminum ones. Quote
MemphisMan Posted August 8, 2018 Author Report Posted August 8, 2018 18 hours ago, kzwslf said: Following are photos of guides I have made on a 3D printer. I do not believe there is an NOS part on the planet. This is incredible! They look amazing. I wish I knew more about 3D printing. So what are your plans going forward with these? You've done something here that can help almost every single vert owner. Nice! 94 olds vert 1 Quote
mybluecutty Posted August 9, 2018 Report Posted August 9, 2018 I’m interested in a pair of these Quote
Imp558 Posted August 9, 2018 Report Posted August 9, 2018 Are there different grades of plastic that can be 3D printed with? Last year we got some covers for the prop shafts on my Son's drone and they broke relatively quickly. Quote
jiggity76 Posted August 13, 2018 Report Posted August 13, 2018 Found this thread Memphis, I'll keep a lookout for any originals but no luck so far. MemphisMan 1 Quote
oldmangrimes Posted August 17, 2018 Report Posted August 17, 2018 I bought a pair of the 3D printed pin cups, they look and fit great! I thought about painting them to protect the plastic from UV damage, but I'll do it later when I paint my windshield frame and sideview mirrors. The first picture is comparing my broken original with the new one, using my calibrated finger gauges The second picture is the pin cup in place. I don't have time to disassemble the header for something like this, so I just dropped them in from the top. My old snap rings had fallen off a few years ago, so my pin cups have been held in place with some double-sided tape as a temporary solution. Now that I have a replacement part, I will use some adhesive to hold them in place. Thanks again, Kzwxlf! I'll post an update here in a year or two (or sooner if they break). 94 olds vert and rich_e777 1 1 Quote
oldmangrimes Posted October 4, 2018 Report Posted October 4, 2018 Update: The pin cups are still functioning well, but after less than two months the lip has started to slightly deform. I'm not sure if it is from the direct sunlight when parked outside with the top down, compression pressure from the top header when it's closed, or if it is from a side-load pressure from the pin when it's engaged causing the lip to bend. Anyway, it's not a big problem because they still fit, do their job, look good, and haven't broken. And I know that 3D-printed plastic isn't very strong so I'm not surprised. I don't regret my purchase and I still very strongly recommend that others also buy them. I'll give another update after a few months of below-freezing temps of winter, or if I notice any more changes. Note: I did not paint them with UV-protection yet. Has anyone else with these 3D-printed pin cups experienced any deformation? Quote
MemphisMan Posted October 4, 2018 Author Report Posted October 4, 2018 I emailed kzwslf, but never heard a response from him. I'd like a couple of pairs. rich_e777 1 Quote
Imp558 Posted October 4, 2018 Report Posted October 4, 2018 This is the place I got my moldmaking rubber and plastic from years ago. It was easy to work with, all you need is a single good one to pull a mold from and you can reproduce infinite replacements for a few cents a piece, and in a variety of colors. There are different grades of plastics and some of them are VERY tough. https://www.smooth-on.com rich_e777 1 Quote
WillCut Posted June 23, 2019 Report Posted June 23, 2019 Did this kzwslf ever publish the 3d file or someone else make one? 3d printers are fairly common now and I'd like to print a set. Quote
rich_e777 Posted June 26, 2019 Report Posted June 26, 2019 On 10/4/2018 at 12:30 PM, MemphisMan said: I emailed kzwslf, but never heard a response from him. I'd like a couple of pairs. Just came across this thread again and was hoping that member was still around. Quote
tonytoca_87 Posted February 12, 2020 Report Posted February 12, 2020 Just curious as a cat whats the purpose of these pin cups? Never noticed if my vert had them Quote
94 olds vert Posted February 12, 2020 Report Posted February 12, 2020 1 minute ago, tonytoca_87 said: Just curious as a cat whats the purpose of these pin cups? Never noticed if my vert had them The purpose your guess is as valid as mine. They function to align the pin from the top into the frame of the windshield. If you ever watch that pin slide into the pin cup when the top is coming down you can see how it will catch the edge of the pin cup and then align the pin so it is in the center of the hole. I imagine it was designed that way because that would give the top the best seal. That is my understand anyways. Being a plastic part between two solid metal pieces they do not last forever. Psych0matt and tonytoca_87 2 Quote
