worb4me Posted March 17, 2017 Report Posted March 17, 2017 1998 GP GT Outside Temperature is usually way off, gas mileage display sometimes is blank, radio occasionally changes stations (AM if it matters), and heater blower even comes on occasionally. Likely culprit? Could this be the same problem causing my charging system to not work, maybe corrosion at ground points? Edit: my Maxiscan MS300 code reader seems to have crapped out the other day. Could that be related? Quote
rich_e777 Posted March 17, 2017 Report Posted March 17, 2017 I havent had a blank display and do not have a stereo currently but my GTP has had the blower randomly come on and the temperature display was off the other day. I`m not having any charging issues or battery related starting issues. I`m also having a time trying t stop water from leaking down through the blower motor since I bought the thing really and suspect that it caused some hidden under dash problems. Quote
