more questions on my cutty 3.4
The CPS is ok and i have no spark, I know this cause i used timing light.
How do i check the power going to coilpacks?
and what other info can you guys give me?
I know this has been going on for a while and u prolly think i'm dumb, but i've never really worked on an engine before, so bear with me please.
on the side of the icm there will be a 2 wire plug, when looking down at it i think its on the right side. that is power to the coil packs. and u used a timing light on a dis vehicle :lol: well if thats all u had
the timing light is just to check for spark...
on the right side of the ICM, there should be a 2wire harness...with the ignition in the ON position, probe the 2 wires wit a mutlimeter in the DC position. It should read around 12 volts going to your ICM...
i know a timing light would be used to check spark i wasn't saying he was trying to cook thanksgiving dinner or somthin. i just said use what u have. and a timing light can also be used to diganose a bad icm.
:lol: :lol:
yeah, i know man, didnt mean anything by that
Check out this diagram. I think the ICM on 3.4 and 3.1 are the same. The two connector socket on the ICM labeled A and B is the power source to the ICM. B is connected to a 10 Amp fuse on the Right Side Underhood Electrical Center while A is connected to the ground.
The link below is what I got when I measure my ICM and Ignition Coil.
http://members.fortunecity.com/slade901/automobile/Ignition_Troubleshooting.htm
Good luck, Adam. Wish I could help you out, but it's kinda like...finals time and stuff. Not like I'd be much help anyway. You let me know if you need me to stand around and pretend I know how to help you.
LMAO..... :lol:
Thanks, thats an awesome diagrams......that might be of help.
  • 3 weeks later...
Go for the stock Delco wires, order them from GM parts direct. You can get them for under a hundred bucks, everything is included.
While you're at it, put some Rapidfire plugs in that bad boy, they run great!
