Grandprix1 Posted February 15, 2017 Report Posted February 15, 2017 How does one go about removing the throttle body on the L36 Grand Prixs? I bought a throttle body spacer and heat shield from ZZP but can't seem to figure it out. Is it as easy as just unbolting it or do you have to remove the throttle connection some how? Also how much coolant am i going to loose? Thanks Grandprix1 Quote
rich_e777 Posted February 15, 2017 Report Posted February 15, 2017 You wont lose any coolant and it should only be 2 maybe 3 bolts and it will pop off. The old gasket may be making it stick, and you can leave the throttle cables attached. I was able to do so on my L67 fairly easy. Quote
Grandprix1 Posted February 15, 2017 Author Report Posted February 15, 2017 Ok thanks. Ive heard on the NA cars such as mine there is a braket that connects to the bottom of them and goes down to the exhuast cross over pipe which needs to be removed. Hopefully thats not the case. I probably should have bought another gasket to go with it but i didnt so ill be gentle with the current gasket. ZZP says its reusable. Quote
Dark Ride Posted February 15, 2017 Report Posted February 15, 2017 Mine did, might have to remove the crossover pipe to get the bracket off, but that's just four bolts as long as they don't shear off. Quote
Imp558 Posted February 15, 2017 Report Posted February 15, 2017 My L36 didn't have a bracket. You might have a little coolant but there shouldn't be enough to worry about that high. The TPS, IACV, and MAF may need unplugged to get it tfree enough to move off the studs. Quote
Grandprix1 Posted February 15, 2017 Author Report Posted February 15, 2017 So it seems kinda touch and go by the car. When I get a warm day I'll go out and take it all apart and see what I'm dealing with Sent from my iPhone using Tapatalk Quote
Grandprix1 Posted February 15, 2017 Author Report Posted February 15, 2017 My car does have the brace. How ever it's on the side of the TB not under neath. It's 1 bolt. Now we will see what the heat shield and throttle body spacer do. I'll probably end up removing it completely Sent from my iPhone using Tapatalk Quote
Grandprix1 Posted February 17, 2017 Author Report Posted February 17, 2017 If I get around to it would anyone be interested in a write up on how to install a TB spacer? Should be common sense but someone might find it useful Sent from my iPhone using Tapatalk Quote
Imp558 Posted February 18, 2017 Report Posted February 18, 2017 I'd be curious if the studs are the right length? Come to think of it I don't even know if an l36 has studs. The l67 does Quote
Grandprix1 Posted February 23, 2017 Author Report Posted February 23, 2017 Yeah it's got studs. Just barely fits with the spacer and heat shield. It seemed to make a difference in power. TB is no longer hot to the touch. Sent from my iPhone using Tapatalk rich_e777 1 Quote
rich_e777 Posted February 23, 2017 Report Posted February 23, 2017 Ive looked at spacers and thought to add one to the list when installing mods down the road, post some pics if you can, wouldnt mind seeing how it looks in there. Quote
