Grandprix1 Posted February 5, 2017 Report Posted February 5, 2017 Has anyone ever done the F Body Brake Upgrade on the Grand Prixs? Im looking into upgrading my brakes and found on ZZP that there is a kit to upgrade to 12" Rotors with F Body Dual Piston calipers. What do you guys think? Grandprix1 Quote
Psych0matt Posted February 5, 2017 Report Posted February 5, 2017 Get the 06 impala dual piston brakes, they should bolt right up rich_e777 1 Quote
94 olds vert Posted February 5, 2017 Report Posted February 5, 2017 (edited) Get the 06 impala dual piston brakes, they should bolt right upYup, and then get GM rotors. GM Part number is 18021015 . You will need different caliper brackets,GM P/N 18029829. That is a cheaper, and just as effective brake upgrade. Edit: that is all 12 inch stuff from GM on the same platform so it bolts up. The Fbody swap requires drilling, threading, and who knows what else. Edited February 5, 2017 by 94 olds vert primergray, NotEnoughGPs, rich_e777 and 2 others 5 Quote
jake91 Posted February 6, 2017 Report Posted February 6, 2017 (edited) Did the SS swap on my Gtp best mod ever. I used the powerstop kit for a 06 impala ss it is the way to go. $253 and you get new rotors, calipers and brackets best bang for your buck. It all bolts right up you just have to bend the break line a bit at the caliper to clear the bleeder screw. http://www.rockauto.com/en/moreinfo.php?pk=4751583&cc=1440301&jnid=543&jpid=4 Edited February 6, 2017 by jake91 Imp558 and 05impalaSS 2 Quote
digitaloutsider Posted March 3, 2017 Report Posted March 3, 2017 I have the F-body brakes on my car, I like them. However, the rotors ZZP supplies are dog shit. I didn't buy their kit, I instead pieced mine together with junkyard calipers, and holy shit are those drilled/slotted rotors trash. Also, I'd have a very hard time paying $200 for what they give you: two modified calipers, some bolts, some crush washers, and cheap pads. Go to the junkyard and pull the calipers off a 4th Gen, just make sure the bleeders open. The F-body swap DOES NOT involve tapping or drilling. Just buy the sleeve from McMaster-Carr that goes inside the caliper bracket bolt holes. I'd do the SS/GXP swap if I found the parts in the yard. Quote
Grandprix1 Posted March 3, 2017 Author Report Posted March 3, 2017 Ok. I'm a little nervous about taking calipers out of the JY just cause I don't know if they are working or the internals are in decent shape. If my cousin still has his 4th gen SS brake calipers I'll grab those. Sent from my iPhone using Tapatalk Quote
rich_e777 Posted March 3, 2017 Report Posted March 3, 2017 (edited) Yup, and then get GM rotors. GM Part number is 18021015 . You will need different caliper brackets,GM P/N 18029829. That is a cheaper, and just as effective brake upgrade. Edit: that is all 12 inch stuff from GM on the same platform so it bolts up. The Fbody swap requires drilling, threading, and who knows what else. Get the 06 impala dual piston brakes, they should bolt right up You people are worse for my wallet than my girlfriend is. Ok. I'm a little nervous about taking calipers out of the JY just cause I don't know if they are working or the internals are in decent shape. If my cousin still has his 4th gen SS brake calipers I'll grab those. Sent from my iPhone using Tapatalk You could get replacement calipers from RockAuto from the car you like them on, then they are new-ish. And alot easier to prep for paint Nothing against JY stuff when you needed it yesterday though, saved me plenty of times. Edited March 3, 2017 by rich_e777 94 olds vert 1 Quote
Grandprix1 Posted March 3, 2017 Author Report Posted March 3, 2017 Yeah that is true. My brakes really aren't bad until you start over heating them. That's more of a pad and rotor issue then a caliper issue. Sent from my iPhone using Tapatalk Quote
White93z34 Posted March 4, 2017 Report Posted March 4, 2017 Ok. I'm a little nervous about taking calipers out of the JY just cause I don't know if they are working or the internals are in decent shape. If my cousin still has his 4th gen SS brake calipers I'll grab those. Sent from my iPhone using Tapatalk I'm not even a little apprehensive, if they don't work you gotta buy new anyhow and now you have a core. Quote
Grandprix1 Posted March 4, 2017 Author Report Posted March 4, 2017 I'm not even a little apprehensive, if they don't work you gotta buy new anyhow and now you have a core. Yes I guess that's true. So In the long wrong it may save you money actually. What I like about the stock current ones is how hard they bite when they are cold Sent from my iPhone using Tapatalk Quote
Grandprix1 Posted March 8, 2017 Author Report Posted March 8, 2017 Would those impala SS brakes fit on stock 16" wheels? I feel like they won't cause the stock single pistons just barely fit Sent from my iPhone using Tapatalk Quote
W30olds Posted March 22, 2017 Report Posted March 22, 2017 Did the SS swap on my Gtp best mod ever. I used the powerstop kit for a 06 impala ss it is the way to go. $253 and you get new rotors, calipers and brackets best bang for your buck. It all bolts right up you just have to bend the break line a bit at the caliper to clear the bleeder screw. http://www.rockauto.com/en/moreinfo.php?pk=4751583&cc=1440301&jnid=543&jpid=4 Nice looking GP man! jake91 1 Quote
jake91 Posted March 22, 2017 Report Posted March 22, 2017 (edited) Thanks! I miss it, sold it last May. Edited March 22, 2017 by jake91 Quote
Imp558 Posted March 23, 2017 Report Posted March 23, 2017 Would that kit Jake posted a link to clear 16" first gen wheels? Quote
jake91 Posted March 23, 2017 Report Posted March 23, 2017 (edited) Id assume i cant imagine a huge difference Edited March 23, 2017 by jake91 Imp558 1 Quote
W30olds Posted March 25, 2017 Report Posted March 25, 2017 Will the Evolution kit sold by Rock Auto fit on a 1995 GP? I tried to ask the sales guy at rock auto and he was dumb as a rock and rude. So I got pissed and hung up on the moron. Grandprix1 and Imp558 2 Quote
Grandprix1 Posted March 26, 2017 Author Report Posted March 26, 2017 I'm probably going to pull some jy calipers and put on. Any things to look for? How much should they run me? I'm getting brand new rotors and SS lines as well Sent from my iPhone using Tapatalk Quote
digitaloutsider Posted March 26, 2017 Report Posted March 26, 2017 Make sure you can break the bleeder loose before you even bother removing them. I personally wouldn't pay more than $20-25 for a junkyard caliper. The Camaro ones I bought for the Regal ran me like $12 a piece. Quote
jake91 Posted March 26, 2017 Report Posted March 26, 2017 I'm probably going to pull some jy calipers and put on. Any things to look for? How much should they run me? I'm getting brand new rotors and SS lines as well Sent from my iPhone using Tapatalk If your doing the ss swap and plan to buy ss lines get the extended ones. It will give you a bit more play as they are at the limit with the stock length Quote
W30olds Posted March 26, 2017 Report Posted March 26, 2017 Unfortunately no 2nd gen cars only Thanks for the reply. That sucks. Wish there were more aftermarket parts available for the 1st Gen cars. Guess I'll just work on the GTO instead. Thanks again for the info. Nas Escobar 1 Quote
Grandprix1 Posted March 28, 2017 Author Report Posted March 28, 2017 I was looking at rock auto at the rear kit for the Grand Prix so everything matches. It's coming up with a bolt pattern on the rears as a 5x117. The bolt pattern on my 02 is a 5x115. Could this be a miss type on their end or are the rears different? Sent from my iPhone using Tapatalk Quote
Imp558 Posted March 28, 2017 Report Posted March 28, 2017 That's a typo, I don't think 117 even exist. Every now and then you'll see 5×114.3, that's a ford pattern that is close enough to interchange with 5×115. Quote
Grandprix1 Posted March 28, 2017 Author Report Posted March 28, 2017 That's a typo, I don't think 117 even exist. Every now and then you'll see 5×114.3, that's a ford pattern that is close enough to interchange with 5×115.Ok its looking to be cheaper to just buy the kit from rock auto then to get jy calipers and buy rotors and pads and lines. I'd do the rear kit just so the calipers match and the rotors match and have a fresh set up all the way around Quote
