2001goldGTP Posted January 17, 2017 Report Posted January 17, 2017 I am basically just looking for the best replacement front stock for my normal '90 fe3 cutlass supreme. The shocks I have in there now are the monroe sensa and they feel blown out compared to other older cars I drive around in. What have you guys used and what where the results. I have no desire to go coil overs. Quote
Galaxie500XL Posted January 17, 2017 Report Posted January 17, 2017 I had KYB GR2's on my '95 Cutlass convertible, which had the FE3 suspension. I was very happy with the firm, but not harsh ride. Others, though, may have better suggestions. Quote
2001goldGTP Posted January 17, 2017 Author Report Posted January 17, 2017 I had KYB GR2's on my '95 Cutlass convertible, which had the FE3 suspension. I was very happy with the firm, but not harsh ride. Others, though, may have better suggestions. i can only find the excel-g ones, the issue is the market is drying up Quote
Psych0matt Posted January 17, 2017 Report Posted January 17, 2017 Iirc the excel-g is the same thing as the gr2s with a new name Quote
2001goldGTP Posted January 17, 2017 Author Report Posted January 17, 2017 thanks did not know that Quote
rich_e777 Posted January 19, 2017 Report Posted January 19, 2017 get strut bearings, bushings and jounce bumpers from KYB as well. Your metal spring plates are probably fine after a good sanding and epoxy painting but the spring bushings are probably going to be stiff as well. Then everything there will be new. Quote
Galaxie500XL Posted January 19, 2017 Report Posted January 19, 2017 That's exactly what I did with my Cutlass..it wasn't even all that expensive.....having the rear alignment done was kind of expensive, though. Quote
pitzel Posted January 28, 2017 Report Posted January 28, 2017 The lower coil spring mounts/lower strut bearings are an important part to replace on a car that old as they tend to rust over time. Yes, this means that the tie rod, ball joint, axle splines, brake caliper, etc., all has to be removed and spring compressors used to take the thing apart. I had the KYB lower strut mount/bearing assemblies on order for 3+ months, and Amazon never could cough them up. Ended up ordering the Monroes for $20 a piece. Hard to imagine there's any difference worth paying twice as much to KYB for. The GR-2's/Excel-G's are nice. Your metal spring plates are probably fine after a good sanding and epoxy painting The bearings are probably all shot after all those years with the water and rust that tends to get involved. By the time you buy new bearings and install them, may as well just replace 'em. I personally would highly advise that one *not* try to refurbish this part unless you have a way to detect fatigue cracks (ie: dye penetration testing, ultrasound, etc.), which 99% of us probably don't have access to! Quote
2001goldGTP Posted February 3, 2017 Author Report Posted February 3, 2017 thanks for the feed back, I have the monroes and well they are only slightly better than when completely blown out. A friend commented man these feel like my bilstiens do when they need to be replaced, they are at about 15K miles. Quote
W30olds Posted March 22, 2017 Report Posted March 22, 2017 I did the rear shocks about 3 months ago. I used the KYB G2's and love them. Ride is tight, but not to harsh. I'd recommend them to anyone. Quote
Psych0matt Posted March 22, 2017 Report Posted March 22, 2017 I have gr2s in my GTP but that's way lowered on right springs and it's still pretty decent imo. I just ordered gr2s for the 06 (DD). Quote
Imp558 Posted March 23, 2017 Report Posted March 23, 2017 I've really liked my Gabriel Ultra struts, and I made use of the lifetime warranty on one of them a while back. Quote
GOT2B GM Posted March 23, 2017 Report Posted March 23, 2017 GR2 or Sensatracs are good Psych0matt, digitaloutsider and White93z34 3 Quote
RobertISaar Posted March 23, 2017 Report Posted March 23, 2017 based on the Sensatracs I have for the MC, I don't know if I would call them quite FE3-like, but they're far less flabby than FE1. Quote
