93 olds vert cluster change
How easy is it to change the analog cluster to a digital one? the correct one for 93 is pretty plane having just speedo odometer and fuel gauge .Do the older clusters from 88 and up fit these cars or are the plugs different and do many mods have to be made to make them work ?
You have to repin the plug or get an adapter made, and put in a new oil sensor (if you want the oil to read properly. Not too hard
  • 6 years later...
