1995-97 Cutlass Supreme owners
Id appreciate any tips on removing the black dashboard bezel in order to get to the radio
It just snaps off. It's held in with clips. get your fingers and grab an edge and pull firmly but gently.
No screws. It's held completely in place by plastic clips. Just pull them loose. It takes a bit if it's the first time your dash has been apart.
Yeah, good luck getting it to come under the top of the dash itself with the damn steering wheel in the way. :roll:
But no screws!
Tilt the steering wheel all the way down, engage your parking brake and move the gear shift all the way down to first (if it's column shift). Then it's not TOO hard to get out from over the steering wheel.
that steering wheel is a bitch for that dash piece. When I put mine back on it wont snap in 100% by the bottom near the center console...pisses me off! :x
put the steering wheel in its lowest position and pull out the tilt lever
Wow....where do you pull? anywhere in particular? This may be the easiest radio install when i ever get to it!
so....are there NO screws, until you take the actual radio out? And you only have to take out that bezel?
jon
jon
Break it loose from the bottom right corner first. I think that's the easiest spot to put a little leverage. My stock radio was held in by 2 or 3 small bolts (8mm? 10mm?) I replaced them with screws.
Yeah I went and did it 2 days ago, 10 minute job for the whole thing. Just dont forget about getting that rubber tab into position in the middle of the gage cluster
