Mark 1997 Cutlass Coupe Posted August 22, 2016 Report Posted August 22, 2016 I've been looking on Craigslist and Ebay for used aftermarket wheels for my car. It came stock with 16 inch wheels. How would I know what 16-18 inch would fit? Used wheels are a deal, but I don't know how to figure out which ones would fit. Quote
Mark 1997 Cutlass Coupe Posted August 22, 2016 Author Report Posted August 22, 2016 Thanks. Is there some kind of template someone sells, or is the size stamped on the inside of the wheel usually? The last thing I want to do is get some wheels, get new tires, and find they don't fit my car. Quote
Nas Escobar Posted August 22, 2016 Report Posted August 22, 2016 The bolt pattern on the Cutlass is 5x115 BUT it is extremely close to 5x114.3 . I don't want to say they're the same thing but to make a long story short, when you put them on there is not a single issue putting a 5x114.3 wheel on a GM FWD car with the 5x114.3. You have to be aware of the backspacing though. High offset wheels won't fit and neither will wheels with a center bore that's smaller than 70.3mm. Mopar wheels fit the GM cars because their center bore is 71.6mm Your biggest concern is clearing the caliper brackets but at the same time not sticking out. Mustang wheels clear the brackets, have a +22 offset but usually come in 9 inch width. Psych0matt 1 Quote
Psych0matt Posted August 22, 2016 Report Posted August 22, 2016 if you know what they came off of you can google what bolt pattern that car has. you may have issues with the center bore or backspacing, but a spacer can take care of the center bore (that's what I have on my GTP). The backspacing could be an issue but if it's off of another fwd car it should be ok. Quote
Mark 1997 Cutlass Coupe Posted August 22, 2016 Author Report Posted August 22, 2016 Is the Cutlass size considered common? I've seen Craigslist ads stating the wheels someone has will fit tons of cars. I just assumed the seller was trying real hard to sell his wheels. Quote
Mark 1997 Cutlass Coupe Posted August 22, 2016 Author Report Posted August 22, 2016 Not right now. In the past I've seen the "my wheels fit 100 cars". Like I said, I thought it was salesmanship. Quote
intern8tion9l Posted August 23, 2016 Report Posted August 23, 2016 Cutlass is somewhere around +40 offset isn't it? That's just as important as bolt pattern Quote
Imp558 Posted August 23, 2016 Report Posted August 23, 2016 There is a plastic gauge to measure bolt circle, I have one. It doesn't have 114.3 on it, just 115. Quote
Nas Escobar Posted August 23, 2016 Report Posted August 23, 2016 Cutlass is somewhere around +40 offset isn't it? That's just as important as bolt pattern Yes it is, but when you go up a size, the offset changes slightly as well. 16 inch Ford Mustang wheels aren't +42 offset but rather +22 and they clear everything on a W body. The problem there is that the wheel is 9 inches wide. A 1st gen can't fit anything more than 8 inches wide. Cadillac wheels don't bolt on to W bodies either because they're high offset. I've been told they're +35 but I have reason to believe it's closer to +53. Long story short, Late 90's, early 2000 DeVille wheels don't fit. They hit the caliper bracket. Same goes for the STS/CTS wheels. Anyways, offset is important but you can go to a lower offset and be okay but not to a higher offset. If your offset is lower, your spokes are more dished in. You CANNOT go negative offset on a W though. Quote
l67ss Posted August 25, 2016 Report Posted August 25, 2016 I have 18×8.5" on a 35mm offset with a 114.3 pattern and no issues on my monte Quote
Nas Escobar Posted August 25, 2016 Report Posted August 25, 2016 I have 18×8.5" on a 35mm offset with a 114.3 pattern and no issues on my monte That's why I made that comment that I was told they were +35mm but I believe they're +53. Quote
