darklotus42 Posted August 17, 2016 Report Posted August 17, 2016 okay I have a 95 olds CS coupe and I want to get rid of my rear mono and upgrade to coilovers. I have a 98 lumina with coilover suspension as a parts car. can I use everything off the donor to do the swap or will I need other parts. Quote
rich_e777 Posted August 17, 2016 Report Posted August 17, 2016 You will need other parts, look at how the mount bolts to the unibody and there is a difference between the Lumina and Cutlass bolt pattern. There are better ways to go about doing it but its going to cost a bit more. I'm planning on doing a coil over swap on my 94 one day, bought most of the parts already but need the mounts. Quote
Nas Escobar Posted August 17, 2016 Report Posted August 17, 2016 The rear suspension on a 95 Cutlass and a 98 Lumina are different. The 95-01 Lumina and 95-99 Monte Carlo are complete different cars from the rest of the 88-96 W body cars on certain things. The rear suspension is too different. If you search how to do rear coilovers on the forum, you'll see how to do the rears. It's a bit complicated but it can be done. Imp558 1 Quote
l67ss Posted August 20, 2016 Report Posted August 20, 2016 Swap top mounts on rear struts and they'll fit.....assuming you mean actual coilovers and not just stock coil springs Quote
