vorador Posted August 12, 2016 Report Posted August 12, 2016 Ok I'm new so sorry if I'm not in the right spot. I have a 94 grand prix se 3100 sfi v6 and 4t60e tranny. The transmission just capped out and if I'm going to replace it ild rather have a manual....just cuz I like shifting. A friend told me a 95 sunbird gt tranny would fit without mods. Just switch the computer hookup. I believe the transmission on the sunbird is a getrag 282. Mg2. So the question is is this true? If not what would it intail? Quote
Padgett Posted August 13, 2016 Report Posted August 13, 2016 Dunno when the F40 started appearing but a 282 and a 3.1 should work with the same parts as a Fiero V6/Getrag. Major issue might be the motor/trans mounts. Quote
mfewtrail Posted August 13, 2016 Report Posted August 13, 2016 Moving this to the powertain section. Quote
l67ss Posted August 13, 2016 Report Posted August 13, 2016 It'll fit the motor but theres quite a few parts and mods needed to fit the car Quote
Heartbeat1991 Posted August 13, 2016 Report Posted August 13, 2016 It's a fairly involved swap, but worth it I think. The hardest part would be locating all the parts. The F40 didn't come out until 2006. That's a far more involved swap. Nas Escobar 1 Quote
digitaloutsider Posted August 13, 2016 Report Posted August 13, 2016 This has been discussed probably hundreds of times on this forum, please search. IIRC, the J-body 282 is not bolt-on and go and more importantly, that doesn't solve for parts like the pedal mounting brackets, clutch hydraulics, etc. I would not attempt this swap without a donor 5-speed W, IMHO. Quote
Heartbeat1991 Posted August 14, 2016 Report Posted August 14, 2016 This has been discussed probably hundreds of times on this forum, please search. IIRC, the J-body 282 is not bolt-on and go and more importantly, that doesn't solve for parts like the pedal mounting brackets, clutch hydraulics, etc. I would not attempt this swap without a donor 5-speed W, IMHO. J-body 282 should be a bolt on. The problem is that a 95 is a 4 cylinder. That trans won't bolt up to the V6 as I recall. Quote
Imp558 Posted August 14, 2016 Report Posted August 14, 2016 I've never looked close at one of these transmissions, but I've been through a bunch of other standards. The 282 doesn't have a separate bellhousing like most standards do? Quote
Heartbeat1991 Posted August 14, 2016 Report Posted August 14, 2016 I've never looked close at one of these transmissions, but I've been through a bunch of other standards. The 282 doesn't have a separate bellhousing like most standards do? It requires the disassembly of the shift rails and a new detent cover to swap them. But if he's talking about using a trans that he has available to him, swapping the housing doesn't help much. Quote
Nas Escobar Posted August 14, 2016 Report Posted August 14, 2016 J-body 282 should be a bolt on. The problem is that a 95 is a 4 cylinder. That trans won't bolt up to the V6 as I recall. The 5 speed Quad 4 won't bolt on. The 2.2 does. That uses the GM Metric bellhouse pattern. Quote
