jiggity76 Posted July 16, 2016 Report Posted July 16, 2016 Can you add the DIC option pretty easily to the Cutty's? Does it matter what motor you have? Quote
Padgett Posted July 16, 2016 Report Posted July 16, 2016 Think it is pulling data from the ALDL stream so as long as the same sequence it may work with a 3.1 or 3.4 but would be different programming for a 3.8 Quote
jiggity76 Posted July 16, 2016 Author Report Posted July 16, 2016 Not sure what the ALDL stream is but thanks for the info. I have a 91 3.4 DOHC car and wondered if it would work. Is it plug and play or a lot of wiring splicing? Would I just have to switch over the mounting bracket where my cubby storage is right now next to my HUD switch? Found a 89 car, not sure if it's got the 2.8 or 3.1. Going to look at it on Sunday. Quote
Psych0matt Posted July 16, 2016 Report Posted July 16, 2016 It will pop right in in place of the cubby, and might be prewired. If so should take five minutes, otherwise splicing is only a few wires Quote
ManicMechanic Posted July 16, 2016 Report Posted July 16, 2016 If your car has ECC, it MAY be pre-wired for the DIC. It may be even without ECC. It also should work okay for the datastream. Quote
jiggity76 Posted July 16, 2016 Author Report Posted July 16, 2016 Great guys! One of the reasons why I'm considering buying the car. What is ECC and is it easy to determine if I have that? Quote
jiggity76 Posted July 16, 2016 Author Report Posted July 16, 2016 Sorry, feel stupid and yes I do have that. Quote
Padgett Posted July 16, 2016 Report Posted July 16, 2016 ALDL - Assembly Line Data Link - a serial data bus that runs around the car. - Like OBD-II but earlier (1981-1995) DataStream - The format of the serial data sent on the ALDL Quote
Daermos Posted July 18, 2016 Report Posted July 18, 2016 ok so does anyone have or know where i can get some internal pics for a gen3 Driver Information Center with digital display. I am specifically looking for the Traction control side with lights.Thanks Robert Quote
jiggity76 Posted July 18, 2016 Author Report Posted July 18, 2016 Thanks for the explanation Padgett. Makes more sense now. Quote
digitaloutsider Posted July 19, 2016 Report Posted July 19, 2016 ok so does anyone have or know where i can get some internal pics for a gen3 Driver Information Center with digital display. I am specifically looking for the Traction control side with lights. Thanks Robert That's a second gen unit. What exactly are you trying to do? Psych0matt 1 Quote
Daermos Posted July 19, 2016 Report Posted July 19, 2016 That's a second gen unit. What exactly are you trying to do? That's weird that's in my gen 3, well I have an odd idea I want to do so need to know what wires go to the lights and switch for a different/custom dic Quote
digitaloutsider Posted July 19, 2016 Report Posted July 19, 2016 You don't have a Gen 3. Your car is a second gen. If you open up the DIC the board is pretty simple. There's not much going on in there. The TRAC OFF and LOW TRAC lights are just pins on the connector I'm pretty sure. Quote
Daermos Posted July 19, 2016 Report Posted July 19, 2016 You don't have a Gen 3. Your car is a second gen. If you open up the DIC the board is pretty simple. There's not much going on in there. The TRAC OFF and LOW TRAC lights are just pins on the connector I'm pretty sure. So a 2002 is a gen 2? Quote
Daermos Posted July 19, 2016 Report Posted July 19, 2016 You don't have a Gen 3. Your car is a second gen. If you open up the DIC the board is pretty simple. There's not much going on in there. The TRAC OFF and LOW TRAC lights are just pins on the connector I'm pretty sure. Yeah I am looking to remove the dic completely other than tcs Quote
Psych0matt Posted July 19, 2016 Report Posted July 19, 2016 So a 2002 is a gen 2? Gen 1 is 88-96 Gen 2 is 97-03 Gen 3 is 04-08 Nas Escobar, digitaloutsider and rich_e777 3 Quote
digitaloutsider Posted July 19, 2016 Report Posted July 19, 2016 Yeah I am looking to remove the dic completely other than tcs All you should need is a momentary contact switch. I'm 99% sure it's not some special data bus thing, someone should have a pinout of the connector. Quote
Daermos Posted July 19, 2016 Report Posted July 19, 2016 Gen 1 is 88-96 Gen 2 is 97-03 Gen 3 is 04-08 Thanks for clarification on the gens Psych0matt 1 Quote
Daermos Posted July 19, 2016 Report Posted July 19, 2016 All you should need is a momentary contact switch. I'm 99% sure it's not some special data bus thing, someone should have a pinout of the connector. Yeah it looks like one main plug on the back, I have a pinout I think on my laptop. If I remember correctly I think there is 3 wires that are marked as part of the tcs system. Quote
Padgett Posted July 20, 2016 Report Posted July 20, 2016 ref gens: my GTP does not look like any of those. Quote
Psych0matt Posted July 20, 2016 Report Posted July 20, 2016 Yes, it does it's not the same trim level obviously digitaloutsider 1 Quote
Nas Escobar Posted July 20, 2016 Report Posted July 20, 2016 ref gens: my GTP does not look like any of those. Yours is the 1st refresh. That picture was of a 88-91 Grand Prix. Quote
Padgett Posted July 20, 2016 Report Posted July 20, 2016 So we need to keep track of generations and refreshes ? Sounds like Volkswagens. Quote
Nas Escobar Posted July 20, 2016 Report Posted July 20, 2016 Not really, your car is considered gen1 regardless of your body kit engine or lights. Most of the stuff in between interchangea Psych0matt 1 Quote
