D M N Posted December 22, 2003 Author Report Posted December 22, 2003 cool....... what i have a weird question my steering wheel is lopsided i have to have it a little to the right to be able to go straight anyone know why?? Quote
JPaganel Posted December 25, 2003 Report Posted December 25, 2003 cool....... what i have a weird question my steering wheel is lopsided i have to have it a little to the right to be able to go straight anyone know why?? Your front end alignment is off. You need to get it aligned. Quote
Lee Posted December 25, 2003 Report Posted December 25, 2003 Hey, before you get an alignment, rotate the front tires side to side. If it still pulls the same way....then get an alignment. Otherwise it's likely tires. Unless you have very new tires already. I had a bad pull and it was tires. Quote
D M N Posted December 25, 2003 Author Report Posted December 25, 2003 thanks, they are new tires. Whats involved when they aligned cars?? Quote
90TGP Posted December 25, 2003 Report Posted December 25, 2003 For STB's, I'd go with Blaze http://www.freewebs.com/92turbole/stb.htm and get the Fork style front brace and heavy duty rear brace. Or you can get two 98+ Buick Regal F-Bar stb's from your local GM dealer. For the front swaybar. You can try to find the factory swaybar from a Lumina Z34. Rear swaybar, go with the Addco 22mm bar http://www.addco.net/ You can get front lowering springs from Suspension Technique through http://www.jcwhitney.com. Look for the 95+ Lumina/Monte Carlo front springs. You can get tubular rear trailing arms from your local GM dealer. They are for the 98+ Grand Prix's, but they will fit on the earlier W-Body's. P/N 12498649 For struts, I would suggest KYB GR2's all around. You can get those through http://www.tirerack.com. It would also be a good time to get the KYB strut mounts. Quote
