Aren't they just normal relays? Any auto parts store if so. Or a junkyard
Well these are all the relays that I can get at Autozone... Thoughts?
• Relay - Heated Seat
• Relay - Radiator Cooling Fan Motor
• Relay - Power Door Lock
• Relay - Blower Motor Cutout
• Relay - Tail Lamps
• Relay - Sunroof
• Relay - A/C Compressor Control
• Relay - Fog Lamp
• Relay - Power Seat
• Relay - EFE Control
• Relay - Horn
• Relay - Anti Diesel
• Relay - Fuel Pump
• Relay - EGR Control
• Relay - Antenna
• Relay - Fast Idle
• Relay - A/C Clutch
• Relay - Throttle Control
• Relay - Cargo Lamp
• Relay - Instrument Panel Cluster
• Relay - Warning Lamp
• A/C Blower Motor Relay Connector
• Door Lock Relay Connector
• Relay Connector
• A/C Relay Connector
Since I started working on my Camaro, and had to replace a ton of relays, I've had better luck in finding relays at O'Reilley parts stores...don't know if you have them in your area, but they've seemed to have things that AutoZone and Advance claimed were no longer available.  Maybe they just have their stuff organized differently.
