ignition key stuck
1998 Grand Prix GT
I think I wanted to roll the car a bit. The battery iwas disconnected, I put the key in and tried to turn it so I could shift tbe shifter. Couldn't put it in neutral, and now the key won't come out. Battery is chatging, what was left in it wasn't enough to start. Will this rectify itself once I'm able to start tne car? Just can't understand why I can't turn it all the way back (I suppose it's in the "on" position) and pull it out.
Put it in drive and then back into park. That is the only mechanism that should be able to do that
Oh, except for the wheel, turn it really hard and see if the lock ring is bound
Had the same issue on my '01 GP GT.
If you remove the small panel below the ignition you can reach in and there should be a cylinder inside of there with a small button on the bottom of it.  See if you can depress this button.  You might also have luck removing the plastic that goes around the bottom of the column.  The button should actuate to allow the key to be removed.
^^to do that, you'd need a long screwdriver or something.  But that is the way I know how
OK, enough juice in jump starter to crank, but not start. Able to get key out
Thanks for the numerous and prompt responses. Cupcakes for everyone!
I could get it with my finger fairly easy on my 02 GP.
Really?  Fat finger club here apparently LOL
My wife recently ran the battery down in our Equinox, same thing.  Apparently, there's a solenoid attached to the lock in the column, and with no power to operate the solenoid, the key is stuck.  I found a couple of YouTube videos where people showed how to take the upper cover off of the steering column right behind the steering wheel, and manually move the solenoid to release the key.  It sounds like a kind of dumb design to me.  If you're stuck somewhere without cables, and leave the car, pretty much anyone with cables could simply jump off your car, and drive away using the convenient key you left behind.
Just out of curiosity why was the key stuck?
The electronic actuator that releases the key is:
  • Shitty, and they break
  • Doesn't work without power
