TGP Z-34 STE Posted April 21, 2016 Report Posted April 21, 2016 I have seen some Gen 1 W-body using 97-03 Grand Prix Wheels. I happened to find one that I like at the junkyard, but unfortunately after I installed the first wheel on my 1991 Pontiac Grand Prix STE, I noticed that the spoke will hit the caliper bracket. Seems like the offset on the rim is different. I wonder has anyone else added some kind of spacer? If so, where could I find it, and would it be worth it? Let me know please. Thanks Quote
Psych0matt Posted April 21, 2016 Report Posted April 21, 2016 If it's close, grind down the caliper a bit Quote
94 olds vert Posted April 21, 2016 Report Posted April 21, 2016 (edited) Edit: ^^Do that^^ Edited April 21, 2016 by 94 olds vert Quote
TGP Z-34 STE Posted April 21, 2016 Author Report Posted April 21, 2016 Thanks, I will try that. Do the 97-03 rims have a shorter offset, meaning that the wheel will be narrower than my factory wheels? Quote
jman093 Posted April 25, 2016 Report Posted April 25, 2016 Yeah, just search if you want to know the offsets. It's in threads. They are a half inch narrower and sit in the wheel well farther. Quote
55trucker Posted April 25, 2016 Report Posted April 25, 2016 It's not the offset of the rim-to-the-hub but the backset location of the hub flange. The Gen 1 wheels have a deeper hub flange backset so as to clear the brake caliper, the Gen 1 brake rotor *hat* is shallower than the Gen 2 brake rotor *hat* which in turn places the caliper further outward. You can mount Gen 1 wheels on a Gen 2 car but you can't mount Gen 2 wheels on a Gen 1 car regardless of the rim offset unless of course one uses a spacer. There is approx 3/32" interference on the rears & slightly less on the fronts. I found out the hard way many years ago. Quote
Padgett Posted April 25, 2016 Report Posted April 25, 2016 BTW wheels are hub centric & if you all you need is 3/32" (2.4 mm) then a 3 mm spacer (5x115) is all you need. This should still allow registering on the hub & use of the stock nuts.. I had a similar problem putting Beretta wheels on a Fiero that rubbed the caliper. These should work. Quote
