1998 3800 camshaft pulley
Grand Prix GT. I'm assuming it's the camshaft pulley. To the left and above the driveshaft pulley. With serpentine belt off, the pulley was moved. When reassembling everything do I have to realign anything i.e a piston at top dead center?
What are you talking about?  The cam gear on a 3800 is chain driven and behind the timing cover.  It's directly above the crankshaft.
Good question LOL? What the h am I talking about? And I`ve replaced timing belts/chains before. Must be the houurs I work.
Okay, so I assume that`S the power steering pump pulley. And in that case ... never mind :)
(And I misspoke above. The belt, not the pulley was removeb. Oi vay).
I think it's the tensioner up and left, if not it's the idler. The PS Pump is way back there.
