swapping cutlass sedan AQ9 seat skins/cushions with GP coupe Seat frame?
  I found a 92 cutlass international with AQ9 seats that are in decent condition but they're from a sedan, and since GP coupe AQ9 seats are more prevalent here than Cutlass seats can i just swap the skins/cushions to the GP seat frame?
I would think so, just don't know how well the shape will line up to the leather
possibly yes.
but...  Coupe and sedan seats are the same seat, except for the tilt mechanism, meaning you should likely only have to change that.  It is a L shaped hinge assembly on the outer side of the seat included the tilt mechanism and hooks on with 4 bolts.  However, because you are looking at AQ9 seats, you may have the trim parts around the lever that need changed... the lever stick through the upholstery on non-AQ9 seats.
good luck!
sweet thanks for the tip.  Can I use any tilt mechanism or does it have to be from an AQ9 coupe seat?
Is there any difference in Regular Cutlass leather rear buckets and AQ9 rear buckets?
  • 1 month later...
I think I would like to have tilt mechanism I my 4 door, I would keep them. Which seats are most comfortable for long trips from all w bodies?
There was a set of quads in a yard near me last time I was there. Burgundy and in rough shape.
Think cushions would be good?
I'll see if I can check on them.
  • 2 weeks later...
Here are the photos I took last summer. I didn't ask the price because they are not graphite, in excellent shape and reupholstering is too expensive, but I'll check. 83ac5ab89dc36aeb3f07d66413d0278f.jpga592def3f31f06ccad4d265c5b4193b1.jpg99eb7fd12098d199f15983ee188296ff.jpgd7b83d284768e7143850cd38674e661d.jpg
Sent from my iPhone using Tapatalk
I have the HUD. The HUD switch was broken, but had the parts I needed to fix mine.
those actually are not too bad shape.  I wonder what condition the cushions are in, being open to elements.  My car seats currently smell dusty, no matter how many times i clean them.  I guess that comes with a car from dusty Texas?
