chronic139 Posted November 6, 2002 Report Posted November 6, 2002 Anyone know how to pull the top dash piece out of a 2 door Grand prix? 1992 is the year. Any help is appreciated. Quote
ismellrealbad Posted November 6, 2002 Report Posted November 6, 2002 on the plastic piece above the guages that comes out to you there should be 2 phillips head screws. take them out. Now try to slide your fingers under, and pull upwards as close to the drives side as you can then again as close to the passenger side, dont try to pull up from the center of it. try to do this without excessive force cuz if you pull too hard you'll break these next 2 mounts....once youve got the close part lifted then just grasp from the center and pull twards you. thats it. you now have access to the instrument cluster and front speakers Quote
no1kicker Posted November 6, 2002 Report Posted November 6, 2002 Is the dash on the 2 door and 4 door GP the same? It looks like it to me, but the junkyards always ask how many doors. Quote
Guest Posted November 6, 2002 Report Posted November 6, 2002 They ook the same, but they are differant (MAYBE). The dash in the 4-door covers the bezels that hold the light, and wiper switches. The 2-door does not. It might be th dash that is differant, or the bezel. Also, as well as the 2 screws under the bezel above the guages, there is also a screw in the glove box. You have to TOTALLY remove the glove box to get to it (there is a small hole, but it is easier to remove it all, that way if you drop the screw, you don't lose it). Once you take the box out, there is a screw up in there. Taylor Quote
chronic139 Posted November 7, 2002 Author Report Posted November 7, 2002 oh I should have also mentioned that there is a HUD unit in this car. That is my main concern as I dont want to fuck it up. Quote
Guest Posted November 7, 2002 Report Posted November 7, 2002 you know that hole in your bezel above the guages, there are 2 screws in there that hold the HUD on. You will need either a universal joint, or a stubby screwdriver to get them out (assuming it is not the 7 mm). Once you get the 2 screws for the HUD out, just lift it out and disconnect the wiring harness (there is a tab in the back, so you will have to pull it towards you while lifting out). Once the HUD is out then you just lift the dash out (there are clips holding it in, so be firm but gentle). taylor Quote
mfewtrail Posted November 7, 2002 Report Posted November 7, 2002 on my 93 two door GP, you take the two phillips screws out above the instrument panel and then you have to take the glove box out...there are several screws holding it in place and then you have to take out a 7mm screw that is up above where the glove box is mounted Quote
