Daermos Posted March 1, 2016 Report Posted March 1, 2016 So as title says when I push down parking brake pedal it goes down but when I try to push to release um it don't lol unless you lift up on catch. Has anyone had this happen?? A buddy of mine said to rig up a spring, that being said any idea what size or type of spring.?? Any ideas would be greatly appreciated!! Thanks guys Sent from my SAMSUNG-SM-G900A using Tapatalk Quote
Cutlass350 Posted March 1, 2016 Report Posted March 1, 2016 It could be a sticking parking brake assembly inside the rear rotors. However, it's more likely a rusty cable. Iirc, there are 3 cables 1) Front to back-Y connection 2) Right Rear 3) Left Rear Also, check out (Some are similar to your car, but not your car) http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c15280218064 http://www.rockauto.com/en/catalog/pontiac,2002,grand+prix,3.1l+v6,1382510,brake/wheel+hub,parking+brake+cable,1696 Good Luck! rich_e777 1 Quote
Daermos Posted March 1, 2016 Author Report Posted March 1, 2016 It could be a sticking parking brake assembly inside the rear rotors. However, it's more likely a rusty cable. Iirc, there are 3 cables 1) Front to back-Y connection 2) Right Rear 3) Left Rear Also, check out (Some are similar to your car, but not your car) http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c15280218064 http://www.rockauto.com/en/catalog/pontiac,2002,grand+prix,3.1l+v6,1382510,brake/wheel+hub,parking+brake+cable,1696 Good Luck! Hey Cutless350 thanks for the info however it does have to do with the parking brake lever my buddy literally grabbed the catch on the lever and it popped right out.... just wont release from pressing on it. man i wish mine had a pull release LOL would make it a bit easier for me to figure out Quote
Heartbeat1991 Posted March 1, 2016 Report Posted March 1, 2016 If you car has the kind of brake where you have to push the pedal a couple times to apply, and then push again to release . .. you'll need to remove the pedal, clean all the old grease out of it and put new grease on it. The old grease solidifies and makes all the mechanisms in there stick. Quote
Daermos Posted March 2, 2016 Author Report Posted March 2, 2016 If you car has the kind of brake where you have to push the pedal a couple times to apply, and then push again to release . .. you'll need to remove the pedal, clean all the old grease out of it and put new grease on it. The old grease solidifies and makes all the mechanisms in there stick. Hmm that makes sense thanks for the info Heartbeat1991, What kind of lube should i use on it once cleaned? Quote
Heartbeat1991 Posted March 2, 2016 Report Posted March 2, 2016 Any grease you want. Lithium grease. Wheel bearing grease. Petroleum jelly . .. They's all kinds of grease . . Quote
Leadfoot Posted March 2, 2016 Report Posted March 2, 2016 Mine did this recently and it turned out the spring had come off on the parking brake assembly. I had to figure out how it went on there and it works again. It was between the assembly and kick panel so it is hard to see. Quote
Daermos Posted March 2, 2016 Author Report Posted March 2, 2016 Mine did this recently and it turned out the spring had come off on the parking brake assembly. I had to figure out how it went on there and it works again. It was between the assembly and kick panel so it is hard to see. thanks for the info Leedfoot, I went to local pull yard and got another park brake assembly hopefully will get it installed today Quote
Daermos Posted March 4, 2016 Author Report Posted March 4, 2016 ::::::::::::::::UPDATE::::::::::::::::::::::::: First and foremost thanks guys for all the insight! What i actually did was go to local pull yard and pull parking brake assembly from donor car! About an hour's worth a work and my hand looking like i got into a fight with a cat, the Parking brake is now fully operational! Quote
