Lumina 3.1 Air Intake PCV Pipe Name???
fredsmythson
Does anyone know the actual name of the air pipe that goes from air intake tube to the right valve cover on a 1999 3.1 engine?  This is a molded plastic pipe with multiple bends.  It's not the one the connects to the PCV valve - this is a direct pipe that "plugs" into the air intake tube.  I can't seem to find one online for a 1999 Chevy Lumina 3.1 engine...  Thanks...
Link to comment
Share on other sites
Thanks!  We can call that plastic pipe "The Part With No Name."  Even the shop manual doesn't have a name for it.  Seems impossible to find.  And I didn't want to find out the magical pricing from the Chevrolet dealer... I was lucky that the pipe on my Lumina broke in half near the air intake hose.  Now I can use that 19/32 hose to connect the two pieces back together. Another win for the Lumina!
Link to comment
Crankcase ventilation hose. Part # 24506734. Dorman makes an aftermarket one as well: 46014.  The GM one is likely a lot better than the Dorman so go with it if you plan to have the car for quite a while. Most aftermarket pieces that have any rubber on them seem to the woefully inadequate to withstand underhood temperatures for long these days.
Link to comment
