tonytoca_87 Posted December 29, 2015 Report Posted December 29, 2015 Hi everyone I'm new to this forum. Does anyone have any experience installing HID'S in there cutlass. I have a 1995 vert and I want to install HID's but was told the low beam bulbs can be replaced. Any feedback would be highly appreciated. Thanks tonytoca_87 1 Quote
94 olds vert Posted December 29, 2015 Report Posted December 29, 2015 Welcome! The old bulbs can be replaced. I am sure there is a write up here on how to do it. tonytoca_87 1 Quote
tonytoca_87 Posted December 30, 2015 Author Report Posted December 30, 2015 Thanks for the quick reply!! If u can send me the link that would be awesome. Thanks tonytoca_87 1 Quote
Psych0matt Posted December 30, 2015 Report Posted December 30, 2015 Mine were a direct swap, however you do have to silicone the new bulbs in like you would with any replacement bulb. I've done it two or three times and both my cutlass I used to have and in my GTP with no issues. tonytoca_87 1 Quote
94 olds vert Posted December 30, 2015 Report Posted December 30, 2015 I had to silicon a 9006 bulb into the back of the housing, but it has held up well. I guess that is all there is to it. Along with mounting the HID ballast. tonytoca_87 1 Quote
tonytoca_87 Posted December 30, 2015 Author Report Posted December 30, 2015 I appreciate the help. I am going to attempt to do it myself. Thanks On 12/30/2015 at 12:10 AM, 94 olds vert said: I had to silicon a 9006 bulb into the back of the housing, but it has held up well. I guess that is all there is to it. Along with mounting the HID ballast. Quote
tonytoca_87 Posted December 30, 2015 Author Report Posted December 30, 2015 Thanks buddy. This forum is very helpful On 12/30/2015 at 12:06 AM, Psych0matt said: Mine were a direct swap, however you do have to silicone the new bulbs in like you would with any replacement bulb. I've done it two or three times and both my cutlass I used to have and in my GTP with no issues. On 12/30/2015 at 12:06 AM, Psych0matt said: Mine were a direct swap, however you do have to silicone the new bulbs in like you would with any replacement bulb. I've done it two or three times and both my cutlass I used to have and in my GTP with no issues. tonytoca_87 1 Quote
55trucker Posted December 30, 2015 Report Posted December 30, 2015 There is a simple youtube video which gives directions as how to cut off the back end of the old 4351 sealed bulb & then remove the retainer to allow one to slip in a replacement bulb & seal it into place. When I did my low beams I replaced the lower lumens rated 9006 bulbs (1100) with higher lumens 9005 (1700) high beam bulbs. still not satisfied with the lamps brightness & the light in front of the car I have ordered an 9005 4300k HID kit for the lows, http://idkerja.top/videos/h4351-to-9006-headlight-conversion?v=XIFgKxkIjHk Quote
