The Burning Rom Posted November 18, 2015 Report Posted November 18, 2015 Almost have the '89 back together and ready for the road. Wondering what people are running for bulbs in the fog lamps..which should really be driving lamps with the way they are positioned. Right now I'm looking at running an 894, which is a 37.5 watt bulb. The factory is an 881, which is a 27ish watt bulb. The 894 also has a clear tip, which should help. There's a 50 watt bulb, but that may be too much heat for the plastic housing. Anyone found anything that works better? Anyone running LEDs that work decent in these housings? I like LED, but I haven't found any in the past that focus decent like halogens. Quote
Heartbeat1991 Posted November 19, 2015 Report Posted November 19, 2015 I've got some LEDs. I think I had interference with one style on the yellow ring. Quote
pshojo Posted November 19, 2015 Report Posted November 19, 2015 Our fog lights are really lacking. My Sebring that I had, fog lights did great job filling in voids from headlights. I miss car for that and factory stereo system Quote
rich_e777 Posted November 23, 2015 Report Posted November 23, 2015 Autozone has an option I believe, but its not with the regular bulbs its on a limited time endcap that has off road lights. I`ll get you a part number tomorrow. Its a halogen bulb. Quote
The Burning Rom Posted November 24, 2015 Author Report Posted November 24, 2015 Autozone has an option I believe, but its not with the regular bulbs its on a limited time endcap that has off road lights. I`ll get you a part number tomorrow. Its a halogen bulb. Sounds good. Let me know the brand/part #. Quote
rich_e777 Posted November 24, 2015 Report Posted November 24, 2015 Damn, walked by it about 10 times today and I completely forgot, I wrote a note and will be working at a different store tomorrow but I can still get the part number. I want to say the manufacturer is Baja or Blazer. Ive looked on the website and couldn't find it. I set the display and I`m pretty sure the very first # in the run was 881 because I was thinking about getting a set for my Cutlass. Quote
rich_e777 Posted November 26, 2015 Report Posted November 26, 2015 Ok its a Blazer International product off their Baja tough line of bulbs, its actually a 880 bulb but it plugs right into the factory harness for my Cutlass, bought a set to day to try them out for $12.99 P/N DF-880BP-2. They put off a noticeable increase over the standard bulbs and put off a white LED sort of light with just a hint of blue. Not as bright as the low beams but close. There is also a similar line of sealed LED mini quads that you could mount inside the bumper cover. That also goes for some that I`m considering for my GTP that will fit the circular shape and mount in a similar way. Quote
Garrett Powered Posted November 27, 2015 Report Posted November 27, 2015 this is the classic fog lamp upgrade Quote
The Burning Rom Posted November 27, 2015 Author Report Posted November 27, 2015 this is the classic fog lamp upgrade Those are 50W bulbs..double the stockers. Any housing issues when running those? Quote
Garrett Powered Posted December 6, 2015 Report Posted December 6, 2015 you have to adjust the beam to go farther down the road is all you gotta worry about Quote
