GTPer Posted October 1, 2015 Report Posted October 1, 2015 So I recently got my engine rebuild. It has less than 1000 miles on it. It starts, runs, and drives good but it has a CEL with three codes. It has a p0717 Input/Turbine Speed Sensor Circuit No Signal, p1350 ignition control system, and p1654 AC circuit something. I just wanted to know if anyone knows how to fix any of these? It's a 97 GTP. I just want to know if's worth fixing the codes or not because I am selling the car and the CEL really scares people and lowers the value of the car. Any help would be greatly appreciated. Quote
Imp558 Posted October 1, 2015 Report Posted October 1, 2015 Transmission not in Park or Neutral can cause 0710, check the position switch and make sure it's alright. A/C control is the green/white wire to the A/C relay from the PCM. That ignition code is a strange one Quote
GTPer Posted October 1, 2015 Author Report Posted October 1, 2015 Transmission not in Park or Neutral can cause 0710, check the position switch and make sure it's alright. A/C control is the green/white wire to the A/C relay from the PCM. That ignition code is a strange one Its p0717 not p0710 Quote
