92 gp coupe brakes...
So on my 92 I replaced both rear calipers and all pads and rotors, bled each side but the pedal is still going to the floor and im not getting much brake pressure. Am I bleeding the brakes wrong? Pumped the brakes until they were hard then bled it out on every caliper and checked and kept up on the fluid. no leaking hoses or lines.. Is there anything that needs to be done while doing this? Key needs to be in "on" position?
Does the emergency/parking brake work?
92-style rear calipers are adjusted by using the park brake.  When replacing calipers, you'll need to set and release the park brake a few times to get proper piston adjustment.
